Champion cooling systems (radiators). Anyone tried ? #1010657
06/10/11 08:09 PM
06/10/11 08:09 PM
USA
K
krw71ragtop Offline OP
K
USA
I need a radiator for a 74' Scamp small block. A moparts member in California has an ad for aluminum radiators in the A-body parts for sale section for a reasonable price. Just wondering if anyone has tried these radiators ? Are they made in the USA ? How was the fit ?
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010658
06/10/11 08:47 PM
06/10/11 08:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a 4 core I bought from Craig. Shipped out real quick. Works great so far. But it will not bolt on a stock fan shroud.
I don't have a fan shroud yet and I've idled in stop and go under 10 mph traffic on the 405 freeway for 20 minutes and didn't get hot with my stroker 416 ~425hp motor. The temp gauge moved a little, but didn't get hot. Once it got some airflow went back to dead on 160. A shroud would take care of it.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: autoxcuda] #1010659
06/10/11 10:05 PM
06/10/11 10:05 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I have 2 on 2 different B bodies and the shroud fit on nicely. Can't confirm A body. Also have a few friends with champion rads and they are very satisfied. Great bang for the buck
Re: Champion cooling systems (radiators). Anyone tried ? [Re: autoxcuda] #1010660
06/10/11 10:37 PM
06/10/11 10:37 PM
USA
K
K
USA
I have a stock 26" radiator part #3673015. It measures 22 1/2" from bottom to the top of the cap. It's about 2" away from the fan blades. Fits in the car just fine. It's too beat up to use.
I purchased a 26" aluminum radiator at a swap meet that measures 24 1/2" from bottom to top of cap. The hood would not close without hitting the cap. I trimmed a piece of the inner hood and got it to close but then realized when I put the fan on it was about a half inch from the radiator. Seems a little close to me. Now I have a new aluminum radiator that I can't use and I don't want to purchase another one and have the same issue's. Do you know how tall your's is ?
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010661
06/10/11 11:32 PM
06/10/11 11:32 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I bought one from the guy you are talking about. I had it within a couple days. I had to drill new mounting holes which tool about 5 minutes. As said before the factory shroud will not fit but I've been fine without it. Mine is a 2-core 26" for a 74 318 Valiant.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010662
06/11/11 12:16 AM
06/11/11 12:16 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I wanted to buy one from Craig but he never got back to me. Not good for business.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: bordin34] #1010663
06/11/11 01:56 AM
06/11/11 01:56 AM
USA
K
K
USA
How close to the radiator is your fan blades ? I'm wondering if I can use the aluminum one I have with about 1/2" clearance ? The mounting holes and shroud mods I expect with after market parts !
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010664
06/11/11 02:17 AM
06/11/11 02:17 AM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Got one for my '69 Super Bee... like others have said, it required enlarging the mounting holes.
It looks OK... I ordered an electric fan and shroud to go with it, and it looks beautiful, but does not even come close to fitting...
Paul
'69 Super Bee 383 EFI Turbo
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010665
06/11/11 02:25 AM
06/11/11 02:25 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I used the Jaguar fan clutch Hayden # 2765. That's with a small block aluminum water pump 70' and up. The 69' down cast iron water pump is shorter.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: autoxcuda] #1010666
06/11/11 04:09 AM
06/11/11 04:09 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Went with my dad and picked it up in Lake Elsinor. Pops is happy with it so far, ive seen the gauge move to 180 in traffic and other then that it stay around 150. Mild 360, mechanical fan and no shroud
When funds allow ill be getting one for my car
Re: Champion cooling systems (radiators). Anyone tried ? [Re: autoxcuda] #1010667
06/11/11 09:32 AM
06/11/11 09:32 AM
USA
K
K
USA
I did not know the earlier cast pumps are shorter. Thanks for the info and picture. Looks like your fan is almost as close as mine is. Maybe I can run this radiator.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010668
06/11/11 10:02 AM
06/11/11 10:02 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I've got a 26" that I purchased on Ebay. It did come from Cali so maybe the same place?? The first one was twisted, couldn't use it. He promptly sent another one. Mounting holes were useless, had to redrill them all, including the shroud holes. The shroud doesn't fit flush against the radiator but looks ok. Cooling is good, no problem there.
Function - A
Fit - D
Customer Service (not sure if it's the same place) - A
For the money, it's a decent radiator. Just be prepared to massage it.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: NITROUSN] #1010669
06/11/11 10:28 AM
06/11/11 10:28 AM
Port Saint Lucie, FL
ChallengerGary Offline
Give me a shout - or PM rather. I am also a distributor for them (but don't want to step on Craig's toes so I will not be advertising them here).
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010670
06/11/11 11:33 AM
06/11/11 11:33 AM
Yes but the inlet is on the DR side and they have a smaller impeller so flow less but if it will solve your clearance prob there are aftermarket versions that flow alot more if a parts house unit is inadequate. MP has one also but $$$$. definitely add the anti cav plate and deburr the casting lines halfway in the 2 water ports in the tim cover & can mill the front of the tim cover to reduce the vane (or anti cav plate) to the flat to ~.040" for a MUCH more efficient pump then adj bolts/spacer length/pulley alignment. Depends how far you want to get into it & just throwing out some stuff that worked 4 me.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: RapidRobert] #1010671
06/11/11 12:08 PM
06/11/11 12:08 PM
USA
K
K
USA
You bring up some good points I didn't think about. Thanks for everyons help here. I just have one more question. You guys that have A-bodies I need to know the height of the radiator or a part number ?
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010672
06/11/11 04:58 PM
06/11/11 04:58 PM
USA
K
K
USA
A shorter clutch for the fan would work too. This picture shows how close it is.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010673
06/11/11 05:55 PM
06/11/11 05:55 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Copper. Thermal. 180 superstat. Old formula works everytime. Ma knew. New/different is not always better.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: DennisH ] #1010674
06/12/11 12:18 AM
06/12/11 12:18 AM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
I bought one with two 12" fans , so I'm not gonna worry about the mechanical fan.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: KY Charger] #1010675
06/12/11 12:59 AM
06/12/11 12:59 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
My fan is about as far as autoxcuda's. I am not running a clutch fan, mine is solid.
Re: Champion cooling systems (radiators). Anyone tried ? [Re: krw71ragtop] #1010676
06/12/11 03:15 AM
06/12/11 03:15 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Seems ok. But you could get get the 2765 Hayden fan clutch that should be shorter.
