<1' Master Cylinders on a budget? #1010560
06/10/11 01:12 PM
06/10/11 01:12 PM
Germany
1964Polara Offline OP
Germany
Looking for a Budget Master Cylinder with a diameter below 1' for my Scarebird Disc Brake Swap on 68 Belvedere Station. No need for the 100 bucks aluminium 15/16 MC from Mopar. Did Mopar put any that small Diamater MC's in cast iron? I used the 1,xx from a 76 Cordoba in another application but with power brakes. For this project I want to keep the brakes manual. Wilwood makes some very cheap 7/8 for example but can I get adapterplates to mount them properly?
Re: <1' Master Cylinders on a budget? [Re: 1964Polara] #1010561
06/10/11 01:19 PM
06/10/11 01:19 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I use 69 C body disc masters.My 65 with reg Mopar manual disc stops great with one.I have one om my kids 62 300 with PBs also.Ive done a few others and always used that master.Reman from Advanced.Rocky
Chrysler Firepower
Re: <1' Master Cylinders on a budget? [Re: 1964Polara] #1010562
06/10/11 04:36 PM
06/10/11 04:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'73-'75 A-body POWER brake master cylinders are 15/16" bore.
BTW, the only 7/8" Wilwood master cylinder that fits your application is $250.
Re: <1' Master Cylinders on a budget? [Re: DoctorDiff] #1010563
06/11/11 08:20 AM
06/11/11 08:20 AM
Germany
Germany
OK but can I use them for my NON Power Scarebird Conversion?
Than I can go with the Aluminium mopar one...
Re: <1' Master Cylinders on a budget? [Re: 1964Polara] #1010564
06/11/11 09:18 AM
06/11/11 09:18 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Brakes sound like a good place to cut corners and go cheap.
Re: <1' Master Cylinders on a budget? [Re: 1964Polara] #1010565
06/11/11 10:05 AM
06/11/11 10:05 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Yes.
Re: <1' Master Cylinders on a budget? [Re: 1964Polara] #1010566
06/11/11 11:51 AM
06/11/11 11:51 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can run the 15/16" bore iron master with manual brakes if you find a push rod retainer grommet.
As far as I know, I'm the only source for 15/16" and 7/8" bore aluminum Mopar master cylinders that are compatable with manual brakes.
