Which rear end to use #1010393
06/10/11 03:03 AM
06/10/11 03:03 AM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
I have a 68 Charger that I'm putting a built 360 in and found two different chunks for the same price they are both posi units one is a 741 with 3.91 gears that has never been run and the other is a 489 with 4.56 gears the car will mainly be street driven and track every once in a while. I'm on a tight budget since my wife lost her job and don't have extra money for gears for the 489 because 3.91 was the gear ratio that I was looking for. The transmission is being beefed up with high performance parts and has a 3000 stall torque converter. I have 17x9.5 rims with 265/40/17 Nitto's 555 just wondering how the 741 will hold up I tend to have a heavy foot.
Re: Which rear end to use [Re: KY Charger] #1010394
06/10/11 03:09 AM
06/10/11 03:09 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
As long as the rear end is setup right, by that I mean, backlash, pinion depth, bearing preload and angles you shouldn't have any problems.
Re: Which rear end to use [Re: BEINGmeISaCRIME] #1010395
06/10/11 10:47 AM
06/10/11 10:47 AM
scratchnfotraction Offline
and the 3.91s are gonna be a lot better on the street than the .56s with 90% street duty
Re: Which rear end to use [Re: BEINGmeISaCRIME] #1010396
06/10/11 10:47 AM
06/10/11 10:47 AM
dogdays Offline
dogdays  Offline
Go with the 741. Remember that the gears only transmit the torque the rear wheels can resist.
So if you are running slicks and have done chassis work so your car hooks well, you need a Dana 60. But if you're running street tires and a nearly stock suspension that 741 will live forever. Plus remember that automatic transmissions can't shock the gears like a stick.
Plus running 4+ gears on the street is a pain unless you're really into hearing engine noise.
R.
Re: Which rear end to use [Re: dogdays] #1010397
06/10/11 04:45 PM
06/10/11 04:45 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
vote for the 3.91 gears
Re: Which rear end to use [Re: johnscudashop] #1010398
06/11/11 11:45 PM
06/11/11 11:45 PM
Bowling Green, KY
K
K
Bowling Green, KY
Thanks for your input guys.
