06 300 power window issue #1010326
06/09/11 11:38 PM
06/09/11 11:38 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
All of a sudden the rear windows will not work. I tried playing with the lockout switch on the driver's door to no effect even though that shouldn't affect the driver's door controls anyway. They also don't work from the rear seat. I just spent an hour reviewing the owners manual, they don't even specify a particular fuse for the windows much less different ones for front and rear - even though there's 4 different ones for the cotton pickin headlights. Any ideas where to look?
Thanks,
Mike
Re: 06 300 power window issue [Re: 1E2C] #1010327
06/10/11 10:46 AM
06/10/11 10:46 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pull the main switch and check for the switch working properly.They usually use a circuit breaker for PWs.Its typically one.Chrysler uses a wierd setup for their switchs.Rocky
Chrysler Firepower
Re: 06 300 power window issue [Re: 1E2C] #1010328
06/10/11 02:30 PM
06/10/11 02:30 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Mine work when tehy want
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
