318 swap to 383 fuel distribution setup questions... #1010093
06/09/11 07:03 PM
06/09/11 07:03 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
I've been chipping away little by little on my 68 Satellite 318 to 383 swap. For reference my 383 will be producing around 400hp at the crank and I will have a demon 750cfm sitting on a dual plane port match aluminum edelbrock intake...
First question is I haven't measured but I'm assuming because my car started out as a no frills 318 that it has 5/16" fuel line... I will have to invest in some 3/8" lines i'm sure? also i was thinking fine lines or inline. Is there another place that might be cheaper? since i'm on a budget.
So i figured since i'm doing that i might as well invest in an electric fuel pump before i purchased a new mechanical one. does anyone have any tips on a nice cheap electric pump that wouldn't starve my motor and be relatively reliable? what about the sending unit, can i get a stock one? I've never had an electric fuel pump, can i get any ol' inline fuel filter? Will i need a regulator? if so can anyone point me in the direction of a nice simple street car regulator?
Thanks in advance for any help. Cheers
Atom
1962 Chrysler 300 convertible 383/727
1970 Dodge A108 Boogie Van 318/727
Re: 318 swap to 383 fuel distribution setup questions... [Re: maxi333] #1010094
06/09/11 07:07 PM
06/09/11 07:07 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
I converted my 68 satellite from a 318 to a 383 and kept the 5/16" fuel line and had no fuel problems. I also ran a electric fuel pump for a while too. I used the Holley Red pump and mounted on the frame rail near the tank. (stock sending unit also)
Re: 318 swap to 383 fuel distribution setup questions... [Re: Bdrainy] #1010095
06/09/11 07:08 PM
06/09/11 07:08 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
I could be wrong but Im pretty sure the 5/16" fuel line is the factory size for the 383...
Re: 318 swap to 383 fuel distribution setup questions... [Re: Bdrainy] #1010096
06/09/11 07:56 PM
06/09/11 07:56 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
This is correct, and you'll be fine with the 5/16" line. My 67 Satellite is a 383 car, now running a 500 horse 451, and still has the orig. Fuel line. No problems here.
Personally, I don't like electric pumps unless you absolutely need them. The added potential of turning a small engine fire into a major disaster just isn't worth it to me. I run an mechanical Carter strip pump and have ano issues feeding an 830 DP @ 111 mph. To each their own, though.
Re: 318 swap to 383 fuel distribution setup questions... [Re: Bdrainy] #1010097
06/10/11 08:52 AM
06/10/11 08:52 AM
Port Saint Lucie, FL
ChallengerGary Offline
Absolutely correct
Re: 318 swap to 383 fuel distribution setup questions... [Re: maxi333] #1010098
06/10/11 12:18 PM
06/10/11 12:18 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Cool keeping that stock line will same me some cash, plus the original line looks in great shape. Thanks! I will definitely go ahead with a new stock sending unit though... you know how those chrysler sending units were lol.
So the holley red pump would be a good match for the 400 horse and the demon 750. My friend is suggesting a separate inline regulator for it what do you think? Any leads on a thrifty nice quality regulator? Also he is suggesting i get a fuel pressure gauge inline between the float bowls?
Thanks in advance!
Atom
