70RR starting problem #1009930
06/09/11 11:10 AM
06/09/11 11:10 AM
Port Reading, NJ
roadrunner7070 Offline OP
Port Reading, NJ
Just started happening yesterday. Went to start the car in park and it reacted like the battery was dead. Charged it and still reacted like it wanted to start but it clicked and grinded a couple times and when you turned the key again nothing happened. Put it in neutral and it started every time. Went back to start it in park and nothing.
Before I take it to my local mechanic is there anything I can look at?
Re: 70RR starting problem [Re: roadrunner7070] #1009931
06/09/11 12:53 PM
06/09/11 12:53 PM
jersey
Spaceman Spiff Offline
jersey
Neutral safety switch
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 70RR starting problem [Re: Spaceman Spiff] #1009932
06/09/11 01:04 PM
06/09/11 01:04 PM
Port Reading, NJ
Port Reading, NJ
I thought about that. If so that switch didn't last more than 2 years.
Re: 70RR starting problem [Re: roadrunner7070] #1009933
06/09/11 01:11 PM
06/09/11 01:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
maybe the trimrings are on too tight?
Re: 70RR starting problem [Re: DAYCLONA] #1009934
06/09/11 01:21 PM
06/09/11 01:21 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: 70RR starting problem [Re: DAYCLONA] #1009935
06/09/11 02:31 PM
06/09/11 02:31 PM
Port Reading, NJ
Port Reading, NJ
I would appreciate you keep your smart ass comments to yourself. I'm trying to get some helpfull information from experienced people to a problem and your childish remarks are not needed! If you can't respond in an adult manner go somewhere else. It appears you and pinkduster clown know nothing about these cars anyway!
Re: 70RR starting problem [Re: roadrunner7070] #1009936
06/09/11 05:21 PM
06/09/11 05:21 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I had a new switch that didn't last but a couple months, good chinese parts we get now.
Re: 70RR starting problem [Re: okie] #1009937
06/09/11 05:30 PM
06/09/11 05:30 PM
Port Reading, NJ
Port Reading, NJ
Sounds good and a cheap fix. I'll swap out a new one. Thanks.
Re: 70RR starting problem [Re: roadrunner7070] #1009938
06/09/11 05:37 PM
06/09/11 05:37 PM
W a jumper wire w alligator clips on each end jump the "grn" male terminal (not the wire you pulled off of the male terminal) on the starter relay to ground & see if will crank/start. If so trace that wire to either the trans/clutch (whichever is app) & see why/adj it so it has continuity to ground or can permanently ground the male lug on the relay being aware that it will now crank/start in any gear/position (potential safety hazard)
Re: 70RR starting problem [Re: roadrunner7070] #1009939
06/09/11 08:39 PM
06/09/11 08:39 PM
jersey
jersey
If you can't a joke, your on the wrong forum.
Lighten up.
I'm a newbie here, and fully expect to get sarcastic responses to questions.
This place IS like family.
Re: 70RR starting problem [Re: roadrunner7070] #1009940
06/09/11 09:38 PM
06/09/11 09:38 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
go ahead and eat it,it's not poo,it's chocolate cake,said the big brother to little brother,gonna have to muscle up some feelings here brother
Re: 70RR starting problem [Re: roadrunner7070] #1009941
06/09/11 09:57 PM
06/09/11 09:57 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
No sense of humor at all. You'll NEED one around here.
The reason your trim rings are too tight is because you are trying to put trim rings for a 6 inch wide wheel onto a 5.5 inch wide rim. Go see your other post.
