Mickey street drag radial rears what to use up front??? #1009855
06/09/11 09:27 AM
06/09/11 09:27 AM
IN
Dartman928 Offline OP
IN
WHat is everyone using for front tires when using a street drag radial for the rear. Also please post what et and mph you are running. Thank you
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009856
06/09/11 11:22 AM
06/09/11 11:22 AM
an8sec70cuda Offline
I used M/T Sportsman Fronts for about 4 years. Took them off when I flat spotted one...little old lady pulled out in front of me.
They drove OK, but were bad about following ruts.
I threw on a pair of 165R15 radial tires and the car drives MUCH better. I just don't like the looks of them since they are a little less than 26" tall and my old Sportsmans were 28".
If someone would make a 28" tall radial that's skinny, it'd be perfect.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mickey street drag radial rears what to use up front??? [Re: an8sec70cuda] #1009857
06/09/11 11:40 AM
06/09/11 11:40 AM
IN
IN
Thanks Chip
I just dont understand why M/T doesn't make a matching tire for there drag street radial. Now I am not sure sure if I want diferent brands on the car
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009858
06/09/11 11:44 AM
06/09/11 11:44 AM
A lot of folks are running the M/T Sportsman S/R radials up front w/ ET Street radials out back. The tallest version is 26" though. I have asked and suggested a few times to Jason Moulton on yellowbullet about a 28" tall version of this tire. He says they have no plans to make one.
CHIP
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009859
06/09/11 11:46 AM
06/09/11 11:46 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I took my sportsmans off the front and put on radials and it turned my challenger into a lamborghini
Chip, i had tall radials on the front of my challenger. think 205/75r15s. firestones, first tire i had ever seen perfectly balanced without weights
165s on the cuda
Re: Mickey street drag radial rears what to use up front??? [Re: sixpackgut] #1009860
06/09/11 11:49 AM
06/09/11 11:49 AM
The 205/75 still looks wide to me.
CHIP
Re: Mickey street drag radial rears what to use up front??? [Re: an8sec70cuda] #1009861
06/09/11 12:01 PM
06/09/11 12:01 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
hard to see
Re: Mickey street drag radial rears what to use up front??? [Re: sixpackgut] #1009862
06/09/11 12:01 PM
06/09/11 12:01 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
another
Re: Mickey street drag radial rears what to use up front??? [Re: sixpackgut] #1009863
06/09/11 12:08 PM
06/09/11 12:08 PM
IN
IN
I only have a 3 1/2 rim. You guys just ran any radial. Are the radials you guys are running speed rates to go 140-150mph?
Thanks for the help
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009864
06/09/11 12:37 PM
06/09/11 12:37 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Thanks for the help
there was a guy at drag week that was running low 7s when his chute didnt open. the radials probably saved his life and car.
http://www.youtube.com/watch?v=bjFieehJwsg
Re: Mickey street drag radial rears what to use up front??? [Re: sixpackgut] #1009865
06/09/11 01:23 PM
06/09/11 01:23 PM
Northern Illinois
Dusted U Offline
Dusted U  Offline
Northern Illinois
these are what I use M T sportsman radials
You've run your mouth, Now it's time to run your car!!
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009866
06/09/11 01:33 PM
06/09/11 01:33 PM
I've use several different types and sizes of tires on the front, M/T ET fronts, 24 inch, 26 inch, Moroso 7.10x15 and the 165x15 radails mounted on a 3.5 or 4.0 inch wide rim. I have mixed then with radials on the rear, M/T ET Street Radials and with the M/T ET Street bias plys, which is not a good mix on the street At the track with no ruts the car drives fine , it doesn't matter which front or rears I mix them with at the track My car runs 128. MPH, not 130 yet It does weigh 3450 with me in it at the track, goes straight as a arrow, usually, at the track It does wonder, hunt, and drive bad on the street mixing radials and bias plys
Re: Mickey street drag radial rears what to use up front??? [Re: Cab_Burge] #1009867
06/09/11 01:39 PM
06/09/11 01:39 PM
Chesterfield Twp. Mi.
John Burdine Offline
i run 27.5 et fronts, have for years. they drive fine.
Re: Mickey street drag radial rears what to use up front??? [Re: sixpackgut] #1009868
06/09/11 02:19 PM
06/09/11 02:19 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Thanks for the help
I run the same tire on my Demon, After seeing that run from Lutz, I was SOLD!!
They seem ok, i pick up a vibration at about abuck 10, but what old mopar dosnt get a few shakes at that speed.
Kasey
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009869
06/09/11 02:24 PM
06/09/11 02:24 PM
Thanks for the help
Nope, not speed rated. Just regular 165R15 radials. They are perfectly fine for the drag strip though. Speed ratings count when you're talking about sustained speeds, not short bursts at the drag strip.
I drove around on the street for 3+ years w/ 26 x 4.5" M/T ET Fronts. They drove the same as the Sportsmans...OK, but wandered and followed ruts. It was ok to me, but the radials up front drive a lot better.
CHIP
Re: Mickey street drag radial rears what to use up front??? [Re: an8sec70cuda] #1009870
06/09/11 03:41 PM
06/09/11 03:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had the MT bias on the frt with bias rears.The car was a nightmare on the street and the strip was just as bad.Put 165 80 15 radials on frt bias rear and its great.Even at 120 it tracks straight and true.Rocky
Chrysler Firepower
Re: Mickey street drag radial rears what to use up front??? [Re: Dusted U] #1009871
06/09/11 04:02 PM
06/09/11 04:02 PM
IN
IN
What size are these? Is that the s/t or s/r ?
Re: Mickey street drag radial rears what to use up front??? [Re: Dartman928] #1009872
06/10/11 12:09 AM
06/10/11 12:09 AM
Northern Illinois
Dusted U Offline
Dusted U  Offline
Northern Illinois
26 X 6.00 R15 LT SPORTSMAN S/R
Re: Mickey street drag radial rears what to use up front??? [Re: Dusted U] #1009873
06/10/11 01:05 AM
06/10/11 01:05 AM
kansas
farmboy Offline
farmboy  Offline
kansas
Some Goodyears I bought at Sam's Club Running 10.50, and the car drives great.
Re: Mickey street drag radial rears what to use up front??? [Re: farmboy] #1009874
06/10/11 08:01 PM
06/10/11 08:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
currently Hancook 185/80R15,have also used Kumho 185/80R15
these are on a 5" rim on my Satellite
tried the 165 too small
low 11's
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
