Re: Mickey street drag radial rears what to use up front???
[Re: Dartman928]
#1009856
06/09/11 11:22 AM
06/09/11 11:22 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I used M/T Sportsman Fronts for about 4 years. Took them off when I flat spotted one...little old lady pulled out in front of me. They drove OK, but were bad about following ruts. I threw on a pair of 165R15 radial tires and the car drives MUCH better. I just don't like the looks of them since they are a little less than 26" tall and my old Sportsmans were 28". If someone would make a 28" tall radial that's skinny, it'd be perfect.
[Re: Dartman928]
#1009858
06/09/11 11:44 AM
06/09/11 11:44 AM
an8sec70cuda
A lot of folks are running the M/T Sportsman S/R radials up front w/ ET Street radials out back. The tallest version is 26" though. I have asked and suggested a few times to Jason Moulton on yellowbullet about a 28" tall version of this tire. He says they have no plans to make one.
[Re: Dartman928]
#1009859
06/09/11 11:46 AM
06/09/11 11:46 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I took my sportsmans off the front and put on radials and it turned my challenger into a lamborghini
Chip, i had tall radials on the front of my challenger. think 205/75r15s. firestones, first tire i had ever seen perfectly balanced without weights
165s on the cuda
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1009860
06/09/11 11:49 AM
06/09/11 11:49 AM
an8sec70cuda
The 205/75 still looks wide to me.
[Re: Dartman928]
#1009864
06/09/11 12:37 PM
06/09/11 12:37 PM
sixpackgut
Charleston
I only have a 3 1/2 rim. You guys just ran any radial. Are the radials you guys are running speed rates to go 140-150mph?
Thanks for the help
there was a guy at drag week that was running low 7s when his chute didnt open. the radials probably saved his life and car.
http://www.youtube.com/watch?v=bjFieehJwsg
[Re: sixpackgut]
#1009865
06/09/11 01:23 PM
06/09/11 01:23 PM
Posts: 71 Northern Illinois
Dusted U
Northern Illinois
these are what I use M T sportsman radials
You've run your mouth, Now it's time to run your car!!
[Re: Dartman928]
#1009866
06/09/11 01:33 PM
06/09/11 01:33 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I've use several different types and sizes of tires on the front, M/T ET fronts, 24 inch, 26 inch, Moroso 7.10x15 and the 165x15 radails mounted on a 3.5 or 4.0 inch wide rim. I have mixed then with radials on the rear, M/T ET Street Radials and with the M/T ET Street bias plys, which is not a good mix on the street At the track with no ruts the car drives fine , it doesn't matter which front or rears I mix them with at the track My car runs 128. MPH, not 130 yet It does weigh 3450 with me in it at the track, goes straight as a arrow, usually, at the track It does wonder, hunt, and drive bad on the street mixing radials and bias plys
[Re: sixpackgut]
#1009868
06/09/11 02:19 PM
06/09/11 02:19 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Thanks for the help
I run the same tire on my Demon, After seeing that run from Lutz, I was SOLD!!
They seem ok, i pick up a vibration at about abuck 10, but what old mopar dosnt get a few shakes at that speed.
Kasey
[Re: Dartman928]
#1009869
06/09/11 02:24 PM
06/09/11 02:24 PM
an8sec70cuda
Thanks for the help
Nope, not speed rated. Just regular 165R15 radials. They are perfectly fine for the drag strip though. Speed ratings count when you're talking about sustained speeds, not short bursts at the drag strip.
I drove around on the street for 3+ years w/ 26 x 4.5" M/T ET Fronts. They drove the same as the Sportsmans...OK, but wandered and followed ruts. It was ok to me, but the radials up front drive a lot better.
[Re: an8sec70cuda]
#1009870
06/09/11 03:41 PM
06/09/11 03:41 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
I had the MT bias on the frt with bias rears.The car was a nightmare on the street and the strip was just as bad.Put 165 80 15 radials on frt bias rear and its great.Even at 120 it tracks straight and true.Rocky
Chrysler Firepower
[Re: Dusted U]
#1009871
06/09/11 04:02 PM
06/09/11 04:02 PM
Posts: 2,792 IN
Dartman928
IN
What size are these? Is that the s/t or s/r ?
[Re: Dusted U]
#1009873
06/10/11 01:05 AM
06/10/11 01:05 AM
Posts: 391 kansas
farmboy
kansas
Some Goodyears I bought at Sam's Club Running 10.50, and the car drives great.
[Re: farmboy]
#1009874
06/10/11 08:01 PM
06/10/11 08:01 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
currently Hancook 185/80R15,have also used Kumho 185/80R15 these are on a 5" rim on my Satellite tried the 165 too small low 11's Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
