Spark Plugs for a 493 big block #1009794
06/09/11 01:52 AM
06/09/11 01:52 AM
Illinois
saukvillage Offline OP
Illinois
I have a 493 big Block using a drag race P-850 Quick Fuel carb, 10.1 compression. What brand/type spark plugs works best in a 493? I am presently using in my 493 NGK R5670-8. Any recommendation shall be appreciated, Thanks
Re: Spark Plugs for a 493 big block [Re: saukvillage] #1009795
06/09/11 06:54 AM
06/09/11 06:54 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
NGK's are very good. Here's an interesting article to help you figure out the rest...
http://www.4secondsflat.com/Spark_plug_reading.html
Re: Spark Plugs for a 493 big block [Re: jbc426] #1009796
06/09/11 07:42 PM
06/09/11 07:42 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Autolite 85s or os it 25s, no it's 85s my memory is slipping. If you are running ignition upgrades such as a MSD up the gap to .060.
Careful, your character's showing!
Re: Spark Plugs for a 493 big block [Re: saukvillage] #1009797
06/10/11 12:06 AM
06/10/11 12:06 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What heads are you running? I like the Nippondenso Iridium plugs in my Savoy with Indy heads and 11-1 compression
Gus
64 Plymouth Savoy
Dana 60
Re: Spark Plugs for a 493 big block [Re: fourgearsavoy] #1009798
06/10/11 01:33 AM
06/10/11 01:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Spark plug reading might be helpful IF they could actually be removed without burning my fingers on the headers.
Re: Spark Plugs for a 493 big block [Re: fourgearsavoy] #1009799
06/10/11 02:35 PM
06/10/11 02:35 PM
Illinois
Illinois
I'm using 906 heads with 2.14" intake valves installed and mildly ported.
Re: Spark Plugs for a 493 big block [Re: saukvillage] #1009800
06/10/11 02:45 PM
06/10/11 02:45 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Those 8's seem a bit cold for you what you have there. With a 10:1 iron headed motor I would think NKG "6" heat range for street driving and "7" if you are racing.
