Re: 904 transmission fluid info.........
[Re: Larry_Dart_360]
#1009682
06/08/11 11:51 PM
06/08/11 11:51 PM
RapidRobert
Dexron 3 is what you'll find avail. Not sure how many qts
[Re: RapidRobert]
#1009683
06/09/11 02:32 AM
06/09/11 02:32 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
empty? converter too?
put 6 qts in it..start in neutral..and add fluid as needed to fill mark on dip stick...
check fluid in neutral...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#1009687
06/09/11 04:36 PM
06/09/11 04:36 PM
Posts: 1,552 Michigan
Kiddart
I have a 4000 on the tight side for sale. this was way to tight on my application if intrested let me know by pm happy to help
Thank you Kiddart
