904 transmission fluid info......... #1009681
06/08/11 10:35 PM
06/08/11 10:35 PM
Newfoundland Canada
Larry_Dart_360 Offline OP
Newfoundland Canada
I am installing my' 72 904 tranny back in my Dart after a 5 year ..."I don't want to look at the damn car scernario."" so I have completely empty of fluid tranny...How much fluid will it take and what kind dextron??? I can't remember....Larry
Re: 904 transmission fluid info......... [Re: Larry_Dart_360] #1009682
06/08/11 11:51 PM
06/08/11 11:51 PM
Dexron 3 is what you'll find avail. Not sure how many qts
Re: 904 transmission fluid info......... [Re: RapidRobert] #1009683
06/09/11 02:32 AM
06/09/11 02:32 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
empty? converter too?
put 6 qts in it..start in neutral..and add fluid as needed to fill mark on dip stick...
check fluid in neutral...
Tony
70 AARCuda Vitamin C
Re: 904 transmission fluid info......... [Re: Larry_Dart_360] #1009684
06/09/11 07:51 AM
06/09/11 07:51 AM
Newfoundland Canada
Newfoundland Canada
Thanks guys...ya converter and transmission empty.
Re: 904 transmission fluid info......... [Re: Larry_Dart_360] #1009685
06/09/11 09:06 AM
06/09/11 09:06 AM
scratchnfotraction Offline
10+ qrts if TC is emprty
slow up on the filling and check about the 7-8 qrt mark and add slowly while runing thru the gears every so often and check in N with it all warmed up
welcome back to your car project
Re: 904 transmission fluid info......... [Re: Larry_Dart_360] #1009686
06/09/11 01:25 PM
06/09/11 01:25 PM
Newfoundland Canada
Newfoundland Canada
Thanks for the info...Not gona matter now cause the converter is Effed...the converter has the two big hairline cracks that come from the notches on the drive...So now I have to find a 3000+ stall converter for a 904...I knew I sould have left the car in the corner inder the covers...
Re: 904 transmission fluid info......... [Re: Larry_Dart_360] #1009687
06/09/11 04:36 PM
06/09/11 04:36 PM
K
Kiddart Offline
Kiddart  Offline
K
I have a 4000 on the tight side for sale. this was way to tight on my application if intrested let me know by pm
happy to help
Thank you
Kiddart
Re: 904 transmission fluid info......... [Re: Kiddart] #1009688
06/09/11 04:53 PM
06/09/11 04:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Best fluid for the old mopars is actually type-F. Keeps the clutches from slipping as much during shifts and makes the trans last longer.
Re: 904 transmission fluid info......... [Re: Larry_Dart_360] #1009689
06/09/11 05:08 PM
06/09/11 05:08 PM
well..spoke to soon,welcome back to your trouble car
good luck with it
