1994 Concord, fuse blows, stupid things happen #1008977
06/08/11 01:34 AM
06/08/11 01:34 AM
Southwestern Ontario Canada
racealittle Offline OP
My sons '94 Concord has blown a fuse about 5 times over the last year.
The fuse is supposed to be for the automatic temperature control.
The ATC unit has been replaced with a new one in the past, and the relay on the unit has been replaced. The AC compressor has been unplugged.
Now for the stupid things that happen when the fuse blows, or is removed when everything seems to be in working order.
1) the ABS light comes on,
2) the automatic temperature contol seems to go to a default setting of full blowing heat throught the defrost vents,
3) the steering effort increases.
Anyone have a clue on how to fix this?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: 1994 Concord, fuse blows, stupid things happen [Re: racealittle] #1008978
06/09/11 12:49 AM
06/09/11 12:49 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
#2 is a result of the HVAC head unit going out. Been there, done that on a '94 Intrepid ES.
There is a fix involving re-soldering the contacts at the back of the head unit. Head over to http://www.dodgeintrepid.net/ and check out the first gen section, as it's a common issue.
Re: 1994 Concord, fuse blows, stupid things happen [Re: In_The_Pink] #1008979
06/09/11 01:38 PM
06/09/11 01:38 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
I was watching, as I recently bought a 95 Concorde.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 1994 Concord, fuse blows, stupid things happen [Re: racealittle] #1008980
06/09/11 01:40 PM
06/09/11 01:40 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I have 1 Concorde and 5 intrepids. One of my intrepids had a fuse that would blow every once in a while when you were making a turn. Once I replaced the cradle bushings it never happened again.
Join dodgeintrepid.net for sure
Re: 1994 Concord, fuse blows, stupid things happen [Re: In_The_Pink] #1008981
06/09/11 05:33 PM
06/09/11 05:33 PM
Thanks for the link,
I have done a search, and gone through 40 pages or so, back to 2002. Still no answer.
I did find the one about the soldering that you mentioned. I can't see any wiring issue yet.
I tried to read ATC codes, won't work for me.
Re: 1994 Concord, fuse blows, stupid things happen [Re: racealittle] #1008982
06/09/11 09:12 PM
06/09/11 09:12 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
It's not a woring issue, it's an internal head unit problem. There used to be someone on eBay who repaired them for $100, but that was a few years ago.
I tried the ATC codes and go nowhere, so I ended up manually moving the HVAC diverter doors and heat valve/door each season. Trust me, unless you have the hands of a three year old, it's not worth trying.
I even considered swapping over to the rotary dial non-ATC HVAC control, but that requires a different HVAC system and setup, so it wasn't worth it to me.
I ended up putting a wood wdges bewtween the plug and back of the head unit, so that it didn't trip into default mode, and that worked fairly well, but all you could control at that point was the fan speed.
As mentioned, the engine cradle bushings are also a known problem on some of the LH cars, but my '94s were in great shape, so I guess I was lucky. Be sure to check yours.
