Help with replacing fuel pump on my 340 #100888
08/06/08 09:37 PM
08/06/08 09:37 PM
S.E. MICH.
Demonizer Offline OP
S.E. MICH.
Need to replace the mechanical fuel pump on my 340. Looks fairly simple. Would appreciate any suggestions as to proper procedure. Thanks in advance.
Re: Help with replacing fuel pump on my 340 [Re: Demonizer] #100889
08/06/08 09:43 PM
08/06/08 09:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Really makes it easy if you have a pipe flare nut open end wrench. A 9/16 deep socket and extension for a 3/88 drive ratchet. As i am putting th new fuel pump into place I like to bump the engine over ever so slowly to find the low spot on the cam accentric. That way you aren't fighting the tension of the pump while trying to start and tighten the bolts.
Re: Help with replacing fuel pump on my 340 [Re: MoparforLife] #100890
08/06/08 10:18 PM
08/06/08 10:18 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You'll need to put RTV sealant on the bolt threads, 1 of them goes through the timing cover and is exposed to oil.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
