Griner TF transbrake questions.... #1008675
06/07/11 03:09 PM
06/07/11 03:09 PM
PA
Z
zooom Offline OP
zooom  Offline OP
Z
PA
My son competes with a SB stroker/TF combo in a lite wt roadster [~1900#] and has been experiencing many problems with the Griner transbrake valve body. We have several TB solenoids to work with & all can be made to function properly on-the-bench, but then act erradically [hit or miss] when installed in the vehicle. The solenoids will periodically stick and the car "creeps [LOL!]" thru the beam....
Both the solenoid & the TB valve body look like proprietary pieces, & would not be easy to duplicate even by a competent machine shop [which we have].
Any suggestions or shared experiences with this stuff?
Re: Griner TF transbrake questions.... [Re: zooom] #1008676
06/07/11 03:54 PM
06/07/11 03:54 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i only know 2 racers using Griners & thats the sort of problem they're having. they've since fixed them but it was solenoid related. they didn't elaberate to me because i was giving them some stick as i use the A&A brake.(better solenoids apparently)
Re: Griner TF transbrake questions.... [Re: rebel] #1008677
06/07/11 04:17 PM
06/07/11 04:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I used one for 6 years up until about 2 years ago, never had a single problem ever crop up with it.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Griner TF transbrake questions.... [Re: zooom] #1008678
06/07/11 05:08 PM
06/07/11 05:08 PM
Are you torqueing the bolts in the valvebody when you install it to the correct spec or just bolting them down?
Re: Griner TF transbrake questions.... #1008679
06/07/11 06:50 PM
06/07/11 06:50 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you're following the installation instructions and it still won't work, contact member 727specialists . He knows more about Griner valve bodies than anyone except Griner himself.
Re: Griner TF transbrake questions.... #1008680
06/07/11 08:26 PM
06/07/11 08:26 PM
PA
Z
zooom Offline OP
zooom  Offline OP
Z
PA
Bolts are torqued to spec. Problem appears to be heat related as solenoid in this type of TB is completely immersed in the ATF. TB operates properly [allowing the car to be backed] when first started but gets progressively more hit or miss as ATF fluid temps approach operating [~200+].
Re: Griner TF transbrake questions.... [Re: zooom] #1008681
06/07/11 08:38 PM
06/07/11 08:38 PM
Guitar Jones Offline
Why don't you just call Griner? They probably are aware of that condition.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Griner TF transbrake questions.... [Re: Guitar Jones] #1008682
06/07/11 08:47 PM
06/07/11 08:47 PM
PA
Z
zooom Offline OP
zooom  Offline OP
Z
PA
Have been trying to contact Griner for several weeks now. Not sure whether he's still in business as phone is never answered....
And, of course, ATI [the original supplier of the Griner TB valve body] won't [or can't?] deal with only the solenoid. They will gladly sell another complete assembly for $$$$ though...
Any leads on Griner would be appreciated as I'm not ready to swap the TF for a 'glide.
Re: Griner TF transbrake questions.... [Re: zooom] #1008683
06/07/11 08:50 PM
06/07/11 08:50 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
PM board member 727specialists . He assembles the valve bodies for Griner. I am not sure Griner himself ever talks on the phone.
Just called Keith, he is going to look in this thread.
Re: Griner TF transbrake questions.... [Re: zooom] #1008684
06/07/11 09:27 PM
06/07/11 09:27 PM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
Never had a problem with my Griner brake and have had it over 10 yrs. You could be getting electrical interference. I run mine thru a relay. Check your grounding of the brake also.
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: Griner TF transbrake questions.... [Re: zooom] #1008685
06/07/11 09:42 PM
06/07/11 09:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
First thing I would do is take a line pressure reading
Re: Griner TF transbrake questions.... [Re: MR_P_BODY] #1008686
06/07/11 11:48 PM
06/07/11 11:48 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
thats what we did and i can't remember what it was but we turned it down .
I've had my griner since 1993 thousands of pass's changed soleniod out
.My next one will be LBA .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Griner TF transbrake questions.... [Re: zooom] #1008687
06/08/11 02:39 AM
06/08/11 02:39 AM
NW Indiana USA
727specialist Offline
NW Indiana USA
I will be at Griners for the rest of this week.
You can call me there 765-296-2955
Or you can reach me at 219-718-3542... Keith
Re: Griner TF transbrake questions.... [Re: 727specialist] #1008688
06/08/11 08:50 AM
06/08/11 08:50 AM
gregsdart Offline
gregsdart  Offline
Just some thoughts. The line pressure was one of them, the other was electrical resistance in the solenoid circuit due to heat buildup. If you could test the solenoid ohms resistance cold, then hot, might show something? I run a relay, and big wire, never had a problem. Griner brake since 2001(?)
Re: Griner TF transbrake questions.... [Re: gregsdart] #1008689
06/08/11 11:06 AM
06/08/11 11:06 AM
PA
Z
zooom Offline OP
zooom  Offline OP
Z
PA
Thanks for all your replies & suggestions. My son will be contacting Keith to discuss further...
Re: Griner TF transbrake questions.... [Re: zooom] #1008690
06/19/11 01:06 PM
06/19/11 01:06 PM
NW Indiana USA
NW Indiana USA
For the record this problem was not the solenoid which is usually the case.
They tried another solenoid and had the same problem.
I don't know if they found the problem or not though. Keith
Re: Griner TF transbrake questions.... [Re: 727specialist] #1008691
07/16/12 04:10 AM
07/16/12 04:10 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I just picked up a trans that has a griner brake. It will be my first brake. I have a question about the solenoid function. does it use oil pressure to hold it open or closed then when the button is pressed it changes? Doesnt seem there is a spring or anything in it to hold it one way or the other I was bench testing it to make sure the solenoid was good. Any info would be great.. Thanks
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Griner TF transbrake questions.... [Re: HOTMOPR] #1008692
07/16/12 08:22 AM
07/16/12 08:22 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Griner transbrake is a fluid release design. Pressure acts on a differential area on the transbrake valve and closes off(pushes out the valve) the pressure from the transbrake hydraulic circuit when the button is not depressed. When the button is depressed, the solenoid pulls in and allows oil pressure to flow to the front clutch and low/rev band. When the button is released, solenoid pull force is absent, and the fluid pressure acting on the differential area forces the transbrake valve out, exhausting pressure from the direct clutches >>>> LAUNCH. The early solenoids do not have internal springs in them. The later ones do, but the spring is not necessary. Fluid release thru the differential area valve is what makes it function. Solenoid winding resistance should be about 1.5 ohms.
John
Re: Griner TF transbrake questions.... [Re: DusterW2] #1008693
07/16/12 12:27 PM
07/16/12 12:27 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Food for thought as I have run a Griner since forever. If the transbrake isengaged with the idle too low it will creep. the line pressure is based on the idle speed. Years ago I had the same issue and I just bumped the idle up 200rpm and never had the problem again.
Greg
Re: Griner TF transbrake questions.... [Re: bcrproducts] #1008694
07/18/12 06:10 PM
07/18/12 06:10 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
Our Ginder t-brake works great 7.70-7.80 times with our combo using 2nd gear start. Keith set up and built trans. Check both band adjustments after a couple of passes after they get stretched & set in.
Good luck.
