Degreeing cam ?? #1008280
06/07/11 12:02 AM
06/07/11 12:02 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I'm installing my Lunati roller. They want it installed on a 106* centerline which is 4* advanced.
The 4* advance is there to make up for timing chain slack, etc once the engine is run. HOWEVER, since I'm running a gear drive, the cam will never lose this 4* of advance. So, should I still install it at 106* or should it be moved? With this motor combo bottom end torque is not an issue so I can afford to give up a bit there.
Re: Degreeing cam ?? [Re: Stanton] #1008281
06/07/11 12:20 AM
06/07/11 12:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if you can afford to give up some bottom end
torque install it straight up.... I like to advance
my cams and I run a gear drive also
Re: Degreeing cam ?? [Re: Stanton] #1008282
06/07/11 01:20 AM
06/07/11 01:20 AM
Delray beach, Florida
P
Performance Only Offline
P
any installed centerline # is just a suggestion. it's always builders choice depending on the application. what seems like optimum for one combo isn't always the same for another. just consider where you want the power band to begin and end, then decide from there.
machine shop owner and engine builder
