high compression small block head gaskets... #1008138
06/06/11 09:30 PM
06/06/11 09:30 PM
utica ny
meus31 Offline OP
meus31  Offline OP
utica ny
what are you guys doing on the small blocksfor head gaskets with around 13 to 1 or so and a stock block. mls or are you using o rings or what let me know ,yes it will have arp head studs. thanks guys.
Re: high compression small block head gaskets... [Re: meus31] #1008139
06/06/11 09:33 PM
06/06/11 09:33 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Use cometic mls gaskets and never look back.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: high compression small block head gaskets... [Re: meus31] #1008140
06/06/11 09:34 PM
06/06/11 09:34 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well at 12.8-1 I had no problems running the Fel-pro 1008 with studs but when I bumped it up to 14-1 the Fel-Pro's lasted about 6 passes now I run Cometics and all has been good
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: high compression small block head gaskets... [Re: meus31] #1008141
06/06/11 09:48 PM
06/06/11 09:48 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Cometics and be done with it.
RIP Monte Smith
Re: high compression small block head gaskets... [Re: CompWedgeEngines] #1008142
06/06/11 09:52 PM
06/06/11 09:52 PM
, PA
sleepyhead416 Offline
, PA
Cometic w/13.8 I also reuse them.
