Over heating .! #1007069
06/05/11 11:03 AM
06/05/11 11:03 AM
Maryville tn
67coronetman Offline OP
Maryville tn
I have a fairly good built 440 bored .040 over Indy heads mild port work oil mods done and a solid lift cam & 1.6 roller rockers TTI step headers and a 727 trans with a boss hog 3200-3600 stall & 391 gears i have a big rad & fan shroud as seen in the picture but i don't have a clutch fan on it and running a 160 stat what could it be.???
Maybe timing. Or what can anyone offer some simple ideas.!
I ask these things cause i have a friend in NY that has a 500ci big block motor in a 69 dart that is a true 9 sec street driven car and he is running a slant six rad with a 160 stat & factory shroud & clutch fan and even on the hottest days it only get to 200 period.!
Old car are me......
Re: Over heating .! [Re: 67coronetman] #1007070
06/05/11 11:58 AM
06/05/11 11:58 AM
#1 is what speed does it overheat. What temp is it reaching? Overheating since built? timing/mixture in ballpark? I'd remove/check the stat for a quick/easy test & when you solve it I'd go to at least a 180 but that's a sep issue.
Re: Over heating .! [Re: RapidRobert] #1007071
06/05/11 12:04 PM
06/05/11 12:04 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
that shroud looks like it would impede air flow at highway speed
Re: Over heating .! [Re: ademon] #1007072
06/05/11 12:11 PM
06/05/11 12:11 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
What temp is it running to? I would think a clutch fan with a factory shroud will work better.
Re: Over heating .! [Re: ademon] #1007073
06/05/11 12:30 PM
06/05/11 12:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
BINGO! That shroud is too tight.
- Stu Harmon
Re: Over heating .! [Re: 67coronetman] #1007074
06/05/11 12:56 PM
06/05/11 12:56 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
the fan blades needs to cut the plane of the shoud to pull air through the radiator. it will only swirl the air as is, and at cruising speed, it will block air from flowing through the radiator.
Re: Over heating .! [Re: ademon] #1007075
06/05/11 10:19 PM
06/05/11 10:19 PM
Maryville tn
Maryville tn
I will check that but it will pull lots of air flow thru the radiator alot very good.!
Re: Over heating .! [Re: feets] #1007076
06/05/11 10:21 PM
06/05/11 10:21 PM
Maryville tn
Maryville tn
To tight as how.? it has room around the fan and pulls air thru very hard so i am just frustarated.!
Re: Over heating .! [Re: 67coronetman] #1007077
06/05/11 10:26 PM
06/05/11 10:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
When you're driving at highway speed lots of air passes through the radiator. If the shroud is too tight the air can't get through. That means air can't pick up heat from the radiator. The radiator gets hot and you overheat.
- Stu Harmon
Re: Over heating .! [Re: 67coronetman] #1007078
06/05/11 10:29 PM
06/05/11 10:29 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
7 blade clutch fan fixed My overheating
Re: Over heating .! [Re: feets] #1007079
06/05/11 10:32 PM
06/05/11 10:32 PM
Maryville tn
Maryville tn
Ok how much room should be from the fan blades to the edge of the shroud.? This is my worst problem i have had with any car ever.
Re: Over heating .! [Re: 67coronetman] #1007080
06/05/11 11:15 PM
06/05/11 11:15 PM
Want the blades (not the tip to shroud clearance but front to rear depth) ~1/2-2/3 into the shroud but I say that's not it . what speed is it overheating (& how hot)
Re: Over heating .! [Re: 67coronetman] #1007081
06/05/11 11:20 PM
06/05/11 11:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yea I don't think is the shroud either, need more details about when it overheats.
Re: Over heating .! [Re: RapidRobert] #1007082
06/05/11 11:23 PM
06/05/11 11:23 PM
Maryville tn
Maryville tn
I need to check something first i had forgot.! I had changed out the water pump and didn't even pay attention to the water pump blade direction.! I know that was real dumb.!
Re: Over heating .! [Re: 67coronetman] #1007083
06/06/11 01:00 AM
06/06/11 01:00 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
1st thing to check is the thermostat. Especially this time of year if the car has sat a lot over the winter. I just got done replacing a Mr. Gasket high flow that was stuck closed in my 451.
Re: Over heating .! [Re: StealthWedge67] #1007084
06/06/11 09:18 AM
06/06/11 09:18 AM
Portage Wisconsin
Lou_Steger Offline
Lou_Steger  Offline
Portage Wisconsin
Can you just pull the shroud off, run it and see what happens. That seems to me the quickest and cheapest place to start
Re: Over heating .! [Re: 67coronetman] #1007085
06/07/11 07:48 PM
06/07/11 07:48 PM
Maryville tn
Maryville tn
Well i took off the water pump and low & behold the blades where way to short & the angle was wrong so i purchased a new water pump and the blades where 1/2 longer & angle was the way it should be ran the car for 30 min in the drive way never got above 170 then drove it around and only got to 185 seems to be working good so far.!!
