D shaped exhuast port and a round exhaust flange ?????? #1007044
06/05/11 10:21 AM
06/05/11 10:21 AM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
What do you guys think about running a flange that has a round port on a D shaped exhaust port.
My new HEMI has a D shaped exhaust port. The flanges I was looking at have round port that is slightly bigger at the widest point of the D shaped port. SO no interference anywhere.
Would it be better to get a D shaped flange and then dolly the tubes to match the flange? Seems like alot of extra work but would it be worth it?
Thanks fellas
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 340RICK] #1007045
06/05/11 10:26 AM
06/05/11 10:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks fellas
Get the proper flange and fit the tube to it... I
make a form for port shape then hammer or press it
in
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: MR_P_BODY] #1007046
06/05/11 10:36 AM
06/05/11 10:36 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
In some of my research, i was told to open the exhaust port up to the round flange and have seen pictures to where others have done that. i was told the intake and exhaust ratio is pretty far off and to do as much work as possible on the exhaust side. i was even told to put a larger valve in
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: sixpackgut] #1007047
06/05/11 12:32 PM
06/05/11 12:32 PM
Marengo, IL
572DartPost Offline
572DartPost  Offline
Marengo, IL
Everything that applies to the intake side also applies to the exhaust side. An exact match would be ideal, a tube bigger than the port is a better scenario than having interference. The bottom of the port is filled in because velocity is slow there, most of the flow in an exhaust port is through the top of the port. So, the top and sides are the most important to match for flow. In most cases, except very high output per cube race motors a slight mismatch at the port to flange transition can help with reversion. I wouldn't open up the port, unless you know porting you could kill velocity in the port. Is it worth it? Up to you, if you are building the headers might as well make it perfect. Is it going to make a 10, 20, 50 hp difference? Probably not.
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 340RICK] #1007048
06/05/11 02:11 PM
06/05/11 02:11 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 52savoy] #1007049
06/05/11 02:41 PM
06/05/11 02:41 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
My tube's are larger than my port's and there is a pretty good step from the port to the tube on the bottom of the port, I am also using a adapter plate to fit the w2/w5 header flange to the head and I am not aware of any performance loss from the port shape that Ryan put in the heads to a round tube flange,, in a perfect world it would be best to make it all match but how much work do you want to do to get there, at least the flange does not overlap and cover part of the port then I would say you need to fix that.
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: dartman366] #1007050
06/05/11 02:54 PM
06/05/11 02:54 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I agree with you on a W-series head but it doesn't work on a raised port Hemi head. They are too high plus have a different bolt pattern.
if the flanges do bolt up, you could always weld a transition plate inside the floor of the header tube(s).
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 52savoy] #1007051
06/05/11 02:57 PM
06/05/11 02:57 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
Rick
my 572-13's are the same way. Get the hammer and dolly out
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 52savoy] #1007052
06/05/11 03:10 PM
06/05/11 03:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I can understand your point.
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: dartman366] #1007053
06/05/11 04:35 PM
06/05/11 04:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There were anti-reversion headers built and sold. Still plenty of conversation about them, do a search.
Here's one.
http://www.custom-car.us/exhaust/header.aspx
Sems from a quick look that there is no formula or design that is proven at this time.
Unless you are going to built another set and can back-to-back A-B-A test them, it would seem like a bunch of effort to try to fix it without knowing what the result is.
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 340RICK] #1007054
06/05/11 06:10 PM
06/05/11 06:10 PM
GO BUCKS !!!!!!!
3
340RICK Offline OP
340RICK  Offline OP
GO BUCKS !!!!!!!
Thx for the input guys...
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 340RICK] #1007055
06/05/11 08:36 PM
06/05/11 08:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
go with ur gut rick,i'd stay with the same shape
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: fishy340] #1007056
06/05/11 08:37 PM
06/05/11 08:37 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
o and i met the man who got ur motor and beat me out! class act mopar dude he is
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: fishy340] #1007057
06/05/11 08:48 PM
06/05/11 08:48 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Took it out to cecil for the 10.0 index sat.Ran good!!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: fishy340] #1007058
06/05/11 08:50 PM
06/05/11 08:50 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think I am ready for that bad ass barracuda....
Re: D shaped exhuast port and a round exhaust flange ?????? [Re: 1967dartgt] #1007059
06/05/11 09:12 PM
06/05/11 09:12 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i just got pro torque to loosen the convert,so i dont know holmes! u might need to give me the break! awesome im glad u got it out.
