Best way to seal thermo housing?
#1006987
06/05/11 03:06 AM
06/05/11 03:06 AM
Posts: 624 Modesto CA
BFASTER
Modesto CA
The thermostat housing gasket leaks on the 440. It had a "plastic" one and it leaked. Then I put a "paper" one on it, and it leaked as soon as I topped off the radiator! So.....for try number three, what is a sure-fire way to prevent that thing from leaking? (the first one had black RTV, and the second had Permatex Super Weatherstrip Adhesive) Any advice would be appreciated.
1969 Dodge Super Bee Hardtop
2007 Nissan Altima 3.5SE
Re: Best way to seal thermo housing?
[Re: BFASTER]
#1006992
06/05/11 10:13 AM
06/05/11 10:13 AM
RapidRobert
Drawfile both surfaces to get em flat w your finest grit wide/flat file
[Re: RapidRobert]
#1006993
06/05/11 10:38 AM
06/05/11 10:38 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I have an old Mr Gasket chrome on my 440.No leaks with a good gasket.Id lay some sandpaper on a flat surface and sand the housing the use a small piece of wood and sand the pump it self to make sure they are both flat.The 3m dosent seal just keeps the gasket in place.Rocky
Chrysler Firepower
[Re: stumpy]
#1006995
06/05/11 01:14 PM
06/05/11 01:14 PM
Posts: 4,322 St. Louis, Mo
318 Stroker
St. Louis, Mo
Those chrome housings are junk.
What he said! I pulled the leaking junk chrome housing and replaced it with a used stock piece, and haven't had a leak since.
[Re: stumpy]
#1006996
06/05/11 03:57 PM
06/05/11 03:57 PM
Posts: 1,012 indiana
mcmopars
indiana
x2,my chrome one i could never get to stop leaking.
[Re: mcmopars]
#1006997
06/05/11 04:08 PM
06/05/11 04:08 PM
BFASTER
Modesto CA
Thank you all for the input! I will drop that chrome piece o' sheite in the garbage. Can hardly see it anyhow once it's mounted; I got A/C.
[Re: BFASTER]
#1006998
06/05/11 04:30 PM
06/05/11 04:30 PM
Posts: 234 Chicago, IL
Moparman440
Chicago, IL
As others mentioned, block sand it flat as they always seem to be warped. Also mentioned, some adapter housings are just junk. If you dont want to replace the housing or need it fixed ASAP, run over to your local parts store and get some Permatex Aviation. I've been using this stuff for years at my shop and its never let me or my techs down. No matter what the bottle says, theres basically no rules with this stuff, within reason:-). I would just make sure the surface is dry and clean. You can use or not use a gasket. The only downside, once its sealed up you cannot reuse any gaskets and you may need to use a roloc disc(scotch bright roloc,cookie ect) and the more aggressive brown to clean the surfaces next time. I've never had an issue with this stuff sealing, even in some bad surface areas, as long as everything is clean/dry. Its approved for aviation which says it all. Let me know if anyone else uses this stuff.
One more thing, let the stuff set up a bit before filling with coolant. Not a super long time but a good 15/20 minutes. The longer you wait the better.
[Re: Mopar_Country]
#1007003
06/06/11 05:41 PM
06/06/11 05:41 PM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I had less luck with local parts store oem one than I have with thick chromed one. The oem from parts stores seem to be so out of round that even if I got the mating surface flat, the hose neck was so mal-shaped I couldn't get the hose to seal.
Facts are stubborn things.
