emergency brake cable on e-body #1006984
06/05/11 02:57 AM
06/05/11 02:57 AM
Axlerod Offline OP
Axlerod  Offline OP
Installing 2.5" TTI x-pipe kit into 71 Challenger, but found emergency brake cable runs right across where x-pipe wants to run. Called TTI and they said Challenger/Cuda should have brake cable running down left side and then over, not across at the cross-member and then back like on mine.
Do any other e-body owners have their cable running across at the cross-member? If you installed an x-pipe system, how did you handle it? Does anyone know of a source for the other type of cable system that runs down the side instead, or is it possible to modify mine?
Thanks for any help
Re: emergency brake cable on e-body [Re: Axlerod] #1006985
06/05/11 03:10 AM
06/05/11 03:10 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 1970 models run down the side.
Re: emergency brake cable on e-body [Re: Alaskan_TA] #1006986
06/05/11 07:58 AM
06/05/11 07:58 AM
IN
ahy Offline
ahy  Offline
IN
On mine, a '70, the cable runs down the left side and clears a 3" X pipe with no problem. When I replaced my cable, I remember Inline tube offered two styles of replacement cables. Its possible you have the other type. A look at their website may help. Also, if you can post a pic of the setup you have that may help.
