welding spring perches on axle #1006875
06/04/11 10:14 PM
06/04/11 10:14 PM
Newfoundland Canada
Larry_Dart_360 Offline OP
Newfoundland Canada
Is it possible to weld spring perches on axle and getting the correct angle without the axle being in the car?. Say the axle is sitting on a set of axle stands ..Can you put an angle finder on the pinion and go from there ??
Re: welding spring perches on axle [Re: Larry_Dart_360] #1006876
06/04/11 10:30 PM
06/04/11 10:30 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Yes it can be done. The main thing you want to be sure of is that you account for any spring angle AS WELL AS the pinion angle. YOu cannot assume they sit flat when mounted.
Careful, your character's showing!
Re: welding spring perches on axle [Re: Larry_Dart_360] #1006877
06/04/11 10:33 PM
06/04/11 10:33 PM
Newfoundland Canada
Newfoundland Canada
Someone must have come across the "stock" specs" for perches...
Re: welding spring perches on axle [Re: Larry_Dart_360] #1006878
06/04/11 11:53 PM
06/04/11 11:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Perches level on bottom, pinion 5* up is stock IIRC.
Is that where they belong on your car...
Re: welding spring perches on axle [Re: RobX4406] #1006879
06/05/11 12:43 AM
06/05/11 12:43 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Stock is stock, but when modified every combination is different. I strongly recommend that you mock up the rear end in the car; you can just snug the U-bolts, put weight on the rear using stands at the same height as tires and use a floor jack at the front of the rear to adjust the angle, then tack or mark the perches in place. Pull the rear and bring it to someone with a BF welder to finish it (I brought our Dana to a metal-works shop all prepped and they welded it for free).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
