62 Plymouth brake lines #1006017
06/03/11 07:56 PM
06/03/11 07:56 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Hi All. I'm replacing the brake lines on my 62 Plymouth Savoy. I somehow chucked the original line back awhile ago..... I know what your all saying I've said it myself. I thought I would be OK buying a front to back brake line from a online brake line manufacturer but what they sent me was something that looks like it belongs on a Imperial No way it will fit and sorry to say their Tech people were no use. Long and short of it, I'm going to put something together myself. I can't remember exactly where the line crosses under or over the spring, or where it crosses at the front. I would like to get it as close to factory as possible. Can anyone help out A picture would be Nice Jack
Re: 62 Plymouth brake lines [Re: 62440] #1006018
06/03/11 09:21 PM
06/03/11 09:21 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Best I can do at the moment.
Re: 62 Plymouth brake lines [Re: 62maxwgn] #1006019
06/04/11 01:24 AM
06/04/11 01:24 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Is the yellow circled part the brake line ? It's kinda hard to see. Does it follow the frame down and cross in front of the spring hanger ?
Re: 62 Plymouth brake lines [Re: 62440] #1006020
06/04/11 03:35 PM
06/04/11 03:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That is fuel line,this may help.Runs along the frame rail to a bracket then a flexible line to the block on axle housing.Nothing under the springs.
Re: 62 Plymouth brake lines [Re: 62maxwgn] #1006021
06/04/11 07:29 PM
06/04/11 07:29 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
The area that I'm intersted in is the steel line routing from the rubber brake hose to where it runs along the rocker panel. The clip on the frame I assume is for the fuel line.
Re: 62 Plymouth brake lines [Re: 62440] #1006022
06/04/11 07:45 PM
06/04/11 07:45 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Hang on until tomorrow and I'll get what you need.
