Filling a dry engine and radiator
#1005906
06/03/11 04:31 PM
06/03/11 04:31 PM
Posts: 344 PA
noplanb
PA
Is your personal preference to pull the stat and top off the block or just fill the radiator and add coolant as needed when it's running?
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Filling a dry engine and radiator
[Re: noplanb]
#1005907
06/03/11 04:56 PM
06/03/11 04:56 PM
Posts: 3,902 Oregon
hooziewhatsit
I drill a tiny 1/16"ish hole in the thermostat and fill the radiator. Top off as necessary.
[Re: prostreet68]
#1005910
06/03/11 11:20 PM
06/03/11 11:20 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Do that all the time if allowed. Hook everything up without thermo and cover housing in place, then fill eng through that opening until it comes right to top then drop thermo in, install gasket and housing-hose. Then bring radiator level up, start it and go. Works great to avoid air pocket issues.
