Carb sounds at WOT #1005655
06/03/11 02:40 AM
06/03/11 02:40 AM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
What is it that makes one carb have that wonderful deep sound at WOT, and another one not? My '88 Gran Fury (old cop car)with the factory 318/Quadrajet was music to my ears when I floored it. Nice deep sound I grew up loving! The 360 crate motor I put in has a Holley 750 #3310, and does not come close to sounding like this. Same air cleaner is run on both. I want that sound I love so much. Thanks.
Facts are stubborn things.
Re: Carb sounds at WOT [Re: larrymopar360] #1005656
06/03/11 04:20 AM
06/03/11 04:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Think of an engine as being an air pump. A car with a free flowing exhaust will likely have less carb noise. The restrictive exhaust causes the fuel and air to resonate longer in the intake tract. I've seen the Diplomat/Gran Fury cop cars... 2 pre-catalytic converters, a y pipe into a single pipe, ANOTHER cat, then a muffler. Certainly NOT a free flowing system by any measure. Another reason... The Quadrajet is a spread bore carburetor with secondaries LARGER than the Holley. If you tried each carb on the same motor, the Q-jet would make more noise.
Finally, the cam timing in the crate motor is surely more aggressive than the cop spec 318. That will affect things too.
I have a cold air kit in my 2007 ram with the HEMI. It ROARS compared to the stock setup. If I ran it without catalytic converters, it would certainly be quieter.
Re: Carb sounds at WOT [Re: Kern Dog] #1005657
06/03/11 05:20 AM
06/03/11 05:20 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, i can understand that. One thing, I did have a catless exhaust on the cop car prior to the engine swap. But I see what you are saying. I guess the combination of spread bore vs square bore and other factors. Too bad. I sure love that sound. thanks.
Re: Carb sounds at WOT [Re: larrymopar360] #1005658
06/03/11 12:04 PM
06/03/11 12:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Removeing cats makes the exhaust louder, it does not quiet down the intake. The reason you carb made that wonderfull sound was the size of the secondaries, think of it like the pipes on a pipe organ, they make noise by air blowing across them, the little ones make higher sounds and the bigger ones make bigger lower sounds. If you really want to here that sound get a thermoquad, they have the biggest secondaries and run an open style air cleaner. As a bonus you will get better MPG with a t-quad than a holley.
Re: Carb sounds at WOT [Re: HotRodDave] #1005659
06/03/11 01:17 PM
06/03/11 01:17 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The 360 has a square bore intake...can I get a thermoquad for square bore, and will it still sound as good? thanks.
Re: Carb sounds at WOT [Re: larrymopar360] #1005660
06/03/11 04:10 PM
06/03/11 04:10 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Define "good" and I'll answer you
Re: Carb sounds at WOT [Re: ScottSmith_Harms] #1005661
06/03/11 10:19 PM
06/03/11 10:19 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
The air valve in the TQ's and Qjets probably helps with the sound.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Carb sounds at WOT [Re: larrymopar360] #1005662
06/03/11 10:47 PM
06/03/11 10:47 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Spread bore carb will give you the "Big sucking sound" you like. Depending on what intake you have, you may be able to make it work. LD340 intakes (maybe others???) were made "as cast" for square bore carbs, but they also cast the flange area with enough extra meat that it can be hogged out to work properly with a spread bore carb.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Carb sounds at WOT [Re: GO_Fish] #1005663
06/04/11 10:44 PM
06/04/11 10:44 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
My 360 has the MP M1 Dual Plane. I guess I will have to live without that sound, at least for now. I guess each intake (spreadbore and squarbore) have their benefits and shortcomings. What is the shortlist? Thanks!
