Carb sounds at WOT
#1005655
06/03/11 02:40 AM
06/03/11 02:40 AM
Posts: 15,879 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
What is it that makes one carb have that wonderful deep sound at WOT, and another one not? My '88 Gran Fury (old cop car)with the factory 318/Quadrajet was music to my ears when I floored it. Nice deep sound I grew up loving! The 360 crate motor I put in has a Holley 750 #3310, and does not come close to sounding like this. Same air cleaner is run on both. I want that sound I love so much. Thanks.
Facts are stubborn things.
Re: Carb sounds at WOT
[Re: Kern Dog]
#1005657
06/03/11 05:20 AM
06/03/11 05:20 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Ok, i can understand that. One thing, I did have a catless exhaust on the cop car prior to the engine swap. But I see what you are saying. I guess the combination of spread bore vs square bore and other factors. Too bad. I sure love that sound. thanks.
[Re: larrymopar360]
#1005658
06/03/11 12:04 PM
06/03/11 12:04 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Removeing cats makes the exhaust louder, it does not quiet down the intake. The reason you carb made that wonderfull sound was the size of the secondaries, think of it like the pipes on a pipe organ, they make noise by air blowing across them, the little ones make higher sounds and the bigger ones make bigger lower sounds. If you really want to here that sound get a thermoquad, they have the biggest secondaries and run an open style air cleaner. As a bonus you will get better MPG with a t-quad than a holley.
[Re: larrymopar360]
#1005662
06/03/11 10:47 PM
06/03/11 10:47 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Spread bore carb will give you the "Big sucking sound" you like. Depending on what intake you have, you may be able to make it work. LD340 intakes (maybe others???) were made "as cast" for square bore carbs, but they also cast the flange area with enough extra meat that it can be hogged out to work properly with a spread bore carb.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#1005663
06/04/11 10:44 PM
06/04/11 10:44 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My 360 has the MP M1 Dual Plane. I guess I will have to live without that sound, at least for now. I guess each intake (spreadbore and squarbore) have their benefits and shortcomings. What is the shortlist? Thanks!
