Re: Turbo ID without tag
[Re: fbs63]
#1005529
06/03/11 11:56 AM
06/03/11 11:56 AM
Posts: 2,260 IL
furious70
IL
take some pics? Get the housings off and measure the inducer and exducer sizes of the wheels.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: fbs63]
#1005533
06/13/11 11:31 AM
06/13/11 11:31 AM
Posts: 2,260 IL
furious70
IL
Does the turbine inlet have any numbers stamped on the inside? .96, 1.23, 1.32, 1.6 would be common.
You'll really need to take the housings off to measure the wheels to know for sure what you have.
[Re: CW25]
#1005539
06/15/11 03:43 PM
06/15/11 03:43 PM
Posts: 2,260 IL
furious70
IL
Not bad at all, a 76mm turbo with an 87mm turbine and .96 housing. You're already on a 1.32 housing, right Curtis? What wheel do you have?
