Transmission Mounting Bolts #1005420
06/02/11 08:26 PM
06/02/11 08:26 PM
USA
JoesMopar Offline OP
USA
Are the transmission mounting bolts the same for a 727 and a 904? I'm doing a swap and have a 727 but not the mounting bolts for it. I don't want to go to bolt it to the engine and find out they're the wrong length, thread count, quantity etc..
Re: Transmission Mounting Bolts [Re: JoesMopar] #1005421
06/02/11 09:08 PM
06/02/11 09:08 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
they worked for me when i swapped a 904-727
Re: Transmission Mounting Bolts [Re: JoesMopar] #1005422
06/02/11 09:12 PM
06/02/11 09:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
all the same bolts
Re: Transmission Mounting Bolts [Re: gtx6970] #1005423
06/02/11 10:16 PM
06/02/11 10:16 PM
scratchnfotraction Offline
correct..same bolt right down to the torque converter bolts
i like to mark the flex plate and TC before I install them to save the hassle of alinement when it in there
you may want to check TC size to make sure you have the correct size flex plate
they have a small and big one and depends on the TC size
the TC does not swap between 727 & 904 either
make sure to swap the shift levers and throttle pressure valve lever from the one comeing out to the one going in.
those should stay with the car with either tranz
Re: Transmission Mounting Bolts [Re: scratchnfotraction] #1005424
06/02/11 10:37 PM
06/02/11 10:37 PM
USA
USA
Thanks for all the info guys
