Victor 440 and Two Scoops Hood #1005374
06/02/11 05:22 PM
06/02/11 05:22 PM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline OP
I got a RB with Stealth heads and a Victor 440, proform 950, can a stock cuda hood work with this setup? Im assuming Id need a drop base air cleaner to start...??? Anyone else run this combo? Thanks.
Don
Street/Strip 73 Barracuda
Re: Victor 440 and Two Scoops Hood [Re: The Cuda Guy] #1005375
06/02/11 09:07 PM
06/02/11 09:07 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Possibly, if you space the k member down. Check out this challenger: http://www.smotherssupercars.com/m73challenger.html
Re: Victor 440 and Two Scoops Hood [Re: forphorty] #1005376
06/02/11 09:19 PM
06/02/11 09:19 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Don, I believe I still have the stock hood your car came with and was planning on installing a 6pk scoop on a flat hood.
Re: Victor 440 and Two Scoops Hood [Re: Mopar-Al] #1005377
06/03/11 09:36 PM
06/03/11 09:36 PM
Queensland,Australia
T-bar Offline
T-bar  Offline
Don't know just yet, but i'm about to go and pick up my Victor 440 for my rb with eddy heads. I plan on using a drop base cleaner, i am also going to try 2' and 3'filter with an exreme top. By the way i have a Cuda with a twin snorkel bonnet. Should have it sorted by this arvo or in the morning i will let you know.
Re: Victor 440 and Two Scoops Hood [Re: T-bar] #1005378
06/05/11 04:09 AM
06/05/11 04:09 AM
T-bar Offline
T-bar  Offline
Ok i tried it and this is the results. Rb block, eddy rpm heads, victor 440 intake, 850 holley with gasket, drop down air cleaner base which is 1 3/8"(drop), 2 1/4" k&n air filter with an x-treme top. All up this gives me about 5/16" of an inch gap between the top of the element and the bottom of the cross brace of the bonnet. Hope this helps.
Re: Victor 440 and Two Scoops Hood [Re: T-bar] #1005379
06/06/11 09:42 AM
06/06/11 09:42 AM
Thanks. This does help. Gives me options.
Don
