How Much Rake?
#1005212
06/02/11 01:36 PM
06/02/11 01:36 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
How many degrees of rake do you folks set up your ladder bar cars?
Re: How Much Rake?
[Re: mopowers]
#1005214
06/04/11 01:53 PM
06/04/11 01:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is there a magic number? I was thinkin 1-2*. Or is it better to have them level?
They should be angled downwards(front down) but your car will determine how much... but with 1* - 2* you would be real close... if you can get more... cool.... normally you cant get enough angle due to ground clearance ![](/ubbthreads/images/graemlins/wave.gif)
Re: How Much Rake?
[Re: MR_P_BODY]
#1005215
06/04/11 02:03 PM
06/04/11 02:03 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I'm new to ladder bars... I was originally in the bottom hole, but was told by a very respected racer that the bottom bar should be level and that I needed to raise mine higher.. He also said that the lower hole settings is for big power motors.. the higher ones were for less power motors.. I dont know.. maybe someone can clarify.. ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: How Much Rake?
[Re: Jeepmon]
#1005216
06/04/11 02:23 PM
06/04/11 02:23 PM
MR_P_BODY
Thats true... but when most guys put the cross bar in they are usually high and you dont have enough holes to even get it level.... higher the bar the harder it hits the tire and vice versa ![](/ubbthreads/images/graemlins/wave.gif)
Re: How Much Rake?
[Re: mopowers]
#1005219
06/04/11 04:16 PM
06/04/11 04:16 PM
MR_P_BODY
Thanks guys!
I was referring to the angle of the car itself (as measured at the rocker panel). I'm finally getting around to installing my ladder bars. I realize the bars should be close to level at ride height for initial set-up. I was just curious what rake angle folks use for their cars. Or if it even matters... I guess I'll shoot for around 1.5* down. and see if I can get the bars level at that point.
Thanks again.
Thats a personal preference thing ALONG with HP more HP you can get away with the front being lower... I happen to like them close to level ![](/ubbthreads/images/graemlins/wave.gif)
Re: How Much Rake?
[Re: mopowers]
#1005221
06/04/11 04:55 PM
06/04/11 04:55 PM
MR_P_BODY
Right on. As always- Thanks Mike! I appreciate it.
Its more of a traction thing... if you can hook with the front end low... cool... but it takes more for the front to get up to or over the CG of the car... BUT you also have more distance to get the front to lift... like everything else in drag racing... its a balance ![](/ubbthreads/images/graemlins/wave.gif)
