Re: A-833 4 speed Input shaft bearing
[Re: Stanton]
#1005096
06/02/11 10:43 AM
06/02/11 10:43 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
The bearing doesn't come out from the front unless you have an 18 spline trans.
HUH ??? if pulling the input shaft AND it's a 23 spline then yes one would have to take the trans apart, but since the front part of the bearing sticks out the front of the case your statement is incorrect because the bearing is already poking out the front of the case.
Maybe it's the the fact that the input shaft won't come out the front on a 23 spline that I was able to pull the bearing off without disassembling the trans, I popped off the snap rings and used 2 screw drivers against the case and was able to pull off the bearing. You'd be amazed what a 17yr old with a set of tools and a natural mechanical aptitude can do.
[Re: JohnRR]
#1005097
06/02/11 12:32 PM
06/02/11 12:32 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Take it apart and fix it right. Regardless of 23 or 18 spline, the input shaft will not come out the front without dropping the cluster. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: crocha617]
#1005099
06/02/11 08:15 PM
06/02/11 08:15 PM
Posts: 8,905 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I was hoping to confirm if I could just unbolt the front bearing retainer and switch the bearing out.
According to everybody ... NO. According to John-boy, yes - but then he tends to condradict everyone.
Who you want to believe is up to you. Personally, and I've done a few and I've NEVER had an input bearing come off the shaft (or go on again) without significant effort. If I ever had one slip on or off with as little effort as John's did I think I'd throw the shaft away.
[Re: 64dodge572]
#1005103
06/02/11 09:17 PM
06/02/11 09:17 PM
Posts: 2,046 ky.
kenworth_goose
ky.
This is untrue. Just took my 23 spline OD apart and removed the front input shaft bearing from the front then took the rest out the back WITHOUT dropping the cluster.
[Re: kenworth_goose]
#1005104
06/03/11 09:58 AM
06/03/11 09:58 AM
JohnRR
The OD trans doesn't impress me, I was able to pull the bearing off the mainshaft, and put it back on by hand , same for the rear bearing on a 727 .
[Re: crocha617]
#1005105
06/03/11 10:50 AM
06/03/11 10:50 AM
JohnRR
It's a 23 spline and all I want to do is change the input shaft bearing. I was hoping to confirm if I could just unbolt the front bearing retainer and switch the bearing out. The trans works great and shifts perfectly. I'm trying to get the car running for the summer and didn't want to send it out for a total rebuild that could take weeks.Thanks.
No you can't just swap it like that, would be nice if one could but it's not that easy. What makes your friend it's the front bearing?
Buy the rebuild kit and you can do it yourself it's not that hard .
