Open exhaust manifolds #1004898
06/01/11 11:27 PM
06/01/11 11:27 PM
USA
JoesMopar Offline OP
USA
Can you run open exhaust manifolds the same way you would open headers for a short period of time? I was asking because I'm going to bring my car to Midas for them to put the exhaust on. I was wondering if I trailer it there if I could start it up for a few minutes to pull it on and off the trailer.
Re: Open exhaust manifolds [Re: JoesMopar] #1004899
06/01/11 11:57 PM
06/01/11 11:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No reason you can't if everything burnable is out of the way.
Re: Open exhaust manifolds [Re: stumpy] #1004900
06/02/11 12:06 AM
06/02/11 12:06 AM
It may burn some paint. I would winch it, The slight bit of extra time/effort will b forgotten when it's done
Re: Open exhaust manifolds [Re: RapidRobert] #1004901
06/02/11 01:17 AM
06/02/11 01:17 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
flex pipe about 3' for each manifold..
Re: Open exhaust manifolds [Re: astjp2] #1004902
06/02/11 03:03 AM
06/02/11 03:03 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
DO THIS or chance the possiblity of hurting the exh valves. IF they get nice and toasty ...and then the cool air hits them .. it can damage them. NEVER seen it happen .. but I have heard of it doing so.
Re: Open exhaust manifolds [Re: dOc !] #1004903
06/02/11 03:32 AM
06/02/11 03:32 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You know, that "valve damage" story has been passed around for years. I have never heard of it actually happening.
I have ran open manifolds before PLENTY of times with zero ill effects. The noise is nearly intolerable though.
Why go to the trouble and expense of using a trailer? Crank 'er up and get it done!
Re: Open exhaust manifolds [Re: Kern Dog] #1004904
06/02/11 04:03 AM
06/02/11 04:03 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
SOME of yurr posts are too !
Re: Open exhaust manifolds [Re: dOc !] #1004905
06/02/11 04:14 AM
06/02/11 04:14 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Thanks for the "kid gloves"
Did you see my newest title? Is it wrong to admit that I like it?
Re: Open exhaust manifolds [Re: Kern Dog] #1004906
06/02/11 04:17 AM
06/02/11 04:17 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Your new title is most appropriate ...... the tribble-maker that U R ! ...
Re: Open exhaust manifolds [Re: dOc !] #1004907
06/02/11 11:52 AM
06/02/11 11:52 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Hi Doc
I am truckless..
Re: Open exhaust manifolds [Re: 340SHORTY] #1004908
06/02/11 08:24 PM
06/02/11 08:24 PM
USA
USA
Thanks for all the info. So where do I find 3" flexible exhaust hose???
Re: Open exhaust manifolds [Re: JoesMopar] #1004909
06/02/11 08:30 PM
06/02/11 08:30 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
If it's a stock application have the shop make you the head pipes, bolt them up and drive it there. It us to be a common practice, back when we had real custom exhaust guys.
Careful, your character's showing!
Re: Open exhaust manifolds [Re: mopar346] #1004910
06/02/11 09:00 PM
06/02/11 09:00 PM
dogdays Offline
dogdays  Offline
Shoot, for $45 call a tow truck and have it carted over. You're going to spend as much or more on headpipes or running around to find some flex.
As for the "warped valves" old wives' tale, I refer to a big Wisconsin 12 hp 1-cylinder we used to run the grain augur on the farm. The muffler blew off and after dark you could see the exhaust valve at yellow heat, straight in the open exhaust port. That engine ran like that for years with hundreds of on-off cycles. As the guy who had to start it with a hand crank, I can say for sure that the exhaust valve wasn't bothered by the abuse.
R.
Re: Open exhaust manifolds [Re: stumpy] #1004911
06/02/11 09:40 PM
06/02/11 09:40 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I doubt you will experience any problems. I have done this quite a few times over the years. Starter wire,speedo and safety switch wires should be out of the way before hand. It's not like your going to go cruising in it.
Re: Open exhaust manifolds [Re: Mopar-Al] #1004912
06/02/11 10:40 PM
06/02/11 10:40 PM
USA
USA
How about when I first fire the engine to break the cam in? It would be at least a 20 min run
Re: Open exhaust manifolds [Re: JoesMopar] #1004913
06/02/11 10:56 PM
06/02/11 10:56 PM
scratchnfotraction Offline
back in the day i used to run my car with no pipe just out the mannys.
loved it at night on the highway,it would have fire shooting down to the ground at 70 mph
never hurt the valves on it
now if it was straight out the exhast ports,I could see cold air rushing it to warp the valves.
