318 truck cranks ??? #1004516
06/01/11 05:05 PM
06/01/11 05:05 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So what is the deal, are they cast or forged? Did they come in say a 1/2 ton 318 or only in the really big trucks with 318s? I have heard they are shot peened, is that true? I may be getting a 71 out of a 71 truck real soon.
Re: 318 truck cranks ??? [Re: HotRodDave] #1004517
06/01/11 05:41 PM
06/01/11 05:41 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The old 318-3 truck cranks were the hot item in the 70s and 80s. They are real strong forged units. You can tell them apart from car cranks because the throws on the rod journals are solid ( no drill hole through the center)The only problem is that these cranks are very heavy. You will have to lighten it up a lot to use with modern rods and pistons which equals $$$ my
Re: 318 truck cranks ??? [Re: HotRodDave] #1004518
06/01/11 10:15 PM
06/01/11 10:15 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
If you can get an old 318 Poly motor they had those cranks in them also. They wouldn't be any heavier than a stock 340 steel crank as far as weight is concerned.
Re: 318 truck cranks ??? [Re: HotRodDave] #1004519
06/01/11 10:50 PM
06/01/11 10:50 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
They did not come in a poly 318. They are heavier than a 340 crank. Take a look at the picture. Notice where the rod bearings ride....its solid. It has to be a few pounds heavier.
Re: 318 truck cranks ??? [Re: R/T1968R/T] #1004520
06/02/11 12:26 PM
06/02/11 12:26 PM
Kalispell Mt.
Kalispell Mt.
So would it be in a 71 1/2 ton?
Re: 318 truck cranks ??? [Re: HotRodDave] #1004521
06/02/11 01:45 PM
06/02/11 01:45 PM
dogdays Offline
dogdays  Offline
Look on the block identifier pad. If there's an "E" there it is a cast crank.
I highly doubt that any 71 half-ton had a forged crank. I've got one in my back yard and it has the "E" on the ID pad. Of course, it's a Mopar, never say never!
The real question is why you think you need a forged crank. 318/340 cranks are not prone to breakage at power numbers the block can handle. Forged cranks don't make more power. Dirt track sbc 350 drivers use cast cranks as a matter of course.
What's happening to the rest of the truck? Out here they are becoming more popular smoothed and dropped.
R.
Re: 318 truck cranks ??? [Re: dogdays] #1004522
06/02/11 05:35 PM
06/02/11 05:35 PM
Kalispell Mt.
Kalispell Mt.
Just an old 318 2wd long bed truck. I am trying to figure how much I can spend to buy the truck based on what I can use and sell. I am thinking about putting my 414 stroker 340 in it so I did not want to throw away a good steel crank that I could sell.
Re: 318 truck cranks ??? [Re: HotRodDave] #1004523
06/02/11 08:13 PM
06/02/11 08:13 PM
dogdays Offline
dogdays  Offline
400+ cubic inches in that truck should give you traction problems. Sounds like fun. My '71 "donor truck" has a front anti-roll bar, but some nimrod cut it with an arc welder. Does your truck have a working bar? It's the first I have ever seen on a beam front axle.
R.
Re: 318 truck cranks ??? [Re: R/T1968R/T] #1004524
06/02/11 10:54 PM
06/02/11 10:54 PM
Goat330 Offline
Goat330  Offline
Weigh both and then tell me honestly which one is heavier.
Re: 318 truck cranks ??? [Re: Goat330] #1004525
06/02/11 11:02 PM
06/02/11 11:02 PM
scratchnfotraction Offline
my 65 poly truck engine had a forged crank
so did the 273 engine I rebuilt
