body work temporary primer
#1004247
06/01/11 12:00 AM
06/01/11 12:00 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
This will be my first try at bodywork, so bear with me. I plan to start fixing some dents in my sheetmetal soon, I plan to grind down to metal, then use a stud welder to pull, then lay down some filler to smooth it out. It will take me a few months I'm sure to get this done (in high humidity). Is there a recommended rattle can product I can use to keep each patch "preserved" without rusting while I work my way around the car. I will need to paint over it later, but I don't have a place to spray two part paint right now. Thanks
Re: body work temporary primer
[Re: convertriple]
#1004248
06/01/11 12:29 AM
06/01/11 12:29 AM
Posts: 299 CA
David Lee
CA
I really have not found any rattle can primer that can hold up real well, but I am no expert in this field
Ah...so many pedestrians, so little time...
[Re: BFASTER]
#1004255
06/02/11 01:05 AM
06/02/11 01:05 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
Just go to an auto body supply place and get some rattle can etching primer to cover for now.
Two coats of some good self-etch in a spray can will be fine until your ready to reprime/repaint. I have some on my car.
I've got some Marhyde self etching primer, but wasnt sure it was moisture proof....anyone know?
[Re: elitecustombody]
#1004257
06/02/11 07:58 AM
06/02/11 07:58 AM
Challenger 1
Cincinnati, Ohio
none of acid etching primers have moisture blocking properties, I'd suggest buying some epoxy primer, do your metal work,brush on epoxy and then do your filler over that, this way the metal will be protected.
Etching primer does nothing except provide a chemical bite for your primer. It is very translucent and has no sealing properties. If your using it seal your body work, you're gonna have problems.
[Re: SeventySatellite]
#1004263
06/03/11 04:09 PM
06/03/11 04:09 PM
Posts: 1,532 off the grid
340B5
off the grid
Urethane primer is not porous like the others.
Yeah, it's got a smallblock.
