body work temporary primer #1004247
06/01/11 12:00 AM
06/01/11 12:00 AM
Missouri
convertriple Offline OP
super gas
super gas
Missouri
This will be my first try at bodywork, so bear with me. I plan to start fixing some dents in my sheetmetal soon, I plan to grind down to metal, then use a stud welder to pull, then lay down some filler to smooth it out. It will take me a few months I'm sure to get this done (in high humidity).
Is there a recommended rattle can product I can use to keep each patch "preserved" without rusting while I work my way around the car. I will need to paint over it later, but I don't have a place to spray two part paint right now.
Re: body work temporary primer [Re: convertriple] #1004248
06/01/11 12:29 AM
06/01/11 12:29 AM
CA
David Lee Offline
David Lee  Offline
CA
I really have not found any rattle can primer that can hold up real well, but I am no expert in this field
Ah...so many pedestrians, so little time...
Re: body work temporary primer [Re: David Lee] #1004249
06/01/11 12:34 AM
06/01/11 12:34 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I agree about rattle can. Im in the middle of bare metal showing on mine too. I would just find a gun a spray it with 2part primer. If it looks bad or gets dust at least it will be sealed up and you can resand when you find a booth. You wont want spray bomb under your primer any ways.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: body work temporary primer [Re: convertriple] #1004250
06/01/11 01:27 AM
06/01/11 01:27 AM
SeventySatellite Offline
Just go to an auto body supply place and get some rattle can etching primer to cover for now.
Re: body work temporary primer [Re: SeventySatellite] #1004251
06/01/11 12:32 PM
06/01/11 12:32 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
go to a body supply store and get some vari-prime. you can brush it on and remove it later with laquer thinner. may take several coats to get the desired coverage. i've done 2 cars this way and it was several years between start and final paint and body work. i stripped them to bare metal then coated them with a brush. maybe some pics later, i don't have them on this computer. dave
Re: body work temporary primer [Re: convertriple] #1004252
06/01/11 01:17 PM
06/01/11 01:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If this is going to be temporary then I would spray the areas with Rustoleum or similar NON-PRIMER. When you're ready for your final finish, sand it all off and prime properly. Primers don't seal out moisture, a rattle can enamel will.
Re: body work temporary primer [Re: SeventySatellite] #1004253
06/01/11 03:45 PM
06/01/11 03:45 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
Two coats of some good self-etch in a spray can will be fine until your ready to reprime/repaint. I have some on my car.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: body work temporary primer [Re: BFASTER] #1004254
06/01/11 05:33 PM
06/01/11 05:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
For small areas buy some real primer and spray in on with a Preval.
http://www.homedepot.com/h_d1/N-5yc1v/R-...mp;ddkey=Search
The reducer required to thin out autobody paint + primers can cause lifting problems when putting it over top of bomb can products.
Re: body work temporary primer [Re: BFASTER] #1004255
06/02/11 01:05 AM
06/02/11 01:05 AM
Missouri
super gas
super gas
Missouri
I've got some Marhyde self etching primer, but wasnt sure it was moisture proof....anyone know?
Re: body work temporary primer [Re: convertriple] #1004256
06/02/11 01:13 AM
06/02/11 01:13 AM
Jacksonville Florida
elitecustombody Offline
none of acid etching primers have moisture blocking properties, I'd suggest buying some epoxy primer, do your metal work,brush on epoxy and then do your filler over that, this way the metal will be protected.
Re: body work temporary primer [Re: elitecustombody] #1004257
06/02/11 07:58 AM
06/02/11 07:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Etching primer does nothing except provide a chemical bite for your primer. It is very translucent and has no sealing properties. If your using it seal your body work, you're gonna have problems.
Re: body work temporary primer [Re: Neil] #1004258
06/02/11 08:28 AM
06/02/11 08:28 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
get some PPG epoxy primer. use the 401 catalyst when you mix it. when you mix epoxy with 401 you can use it for a week without it catalysing. then mix a small amount in a sealed container, spray your small spots, then pour it back into the container and rinse the sprayer. if you put the mixed epoxy in the fridge it should be good to spray for several weeks.
perception is 90% of reality
Re: body work temporary primer [Re: Mr T2U] #1004259
06/03/11 12:25 AM
06/03/11 12:25 AM
Missouri
super gas
super gas
Missouri
Some good idea's, I will try to use a "real" primer, even if I have to brush it on.
Re: body work temporary primer [Re: convertriple] #1004260
06/03/11 02:53 PM
06/03/11 02:53 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
finally able to get to the computer my pics are on. 1st pic you see the door jamb is stripped ready to brush on the vari-prime. the quater is done but you can see i've reworked the wheel-well metal wise but not added any filler yet. see the dents?. i was waiting at that point to see who was going to do the final paint, me or someone else and usally paint guys want do do their own filler work so they know what is there. tech at the paint store said he wouldn't recommend driving or exposing the car to weather with just the vari-prime on but you can see that wasn't happening soon, lol
Re: body work temporary primer [Re: 3ddart] #1004261
06/03/11 03:00 PM
06/03/11 03:00 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
2nd pic shows the other side at a later date and i've strpped the roof by then. as stated earlier, when paint time came the paint guy da'ed the body and i washed down the places he could't get to with laquer thinner to remove the vari-prime.
Re: body work temporary primer [Re: 3ddart] #1004262
06/03/11 03:08 PM
06/03/11 03:08 PM
This whole post has got me thinking differently now. I had been using etching primer for temporary protection and then removing it at a later time to spray with epoxy. From now on I'm just going to spray with epoxy and be done with it. I'm going to give this thing a try for the smaller areas...
Here's a couple of videos I found for it...
http://www.youtube.com/watch?v=t1nrWz0Ohcg
http://www.youtube.com/watch?v=Fpbh3tLyfss&feature=related
Re: body work temporary primer [Re: SeventySatellite] #1004263
06/03/11 04:09 PM
06/03/11 04:09 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Urethane primer is not porous like the others.
Yeah, it's got a smallblock.
Re: body work temporary primer [Re: SeventySatellite] #1004264
06/03/11 06:47 PM
06/03/11 06:47 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
I prefer this demo clip of the Preval sprayer in action !
http://www.youtube.com/watch?v=-ZKWFzlPfyY&feature=related
Re: body work temporary primer [Re: MileHighDart] #1004265
06/03/11 08:21 PM
06/03/11 08:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I won't ask how you found that one!
