overheating #1004220
05/31/11 11:45 PM
05/31/11 11:45 PM
Western NY
Xlr8us Rapidus Offline OP
super gas
super gas
Western NY
Fairly new 472 Hemi, 10-71 BDS blower, new Be Cool rad, electric water pump, electric puller fans and 180 deg t-stat. After idling for about 5 minutes temp goes right up to 210. Upper hose is cool to the touch, lower hose is hot. Top of rad is also cool to the touch, bottom is hot. Can the water pump possibly be wired to run backwards? Or maybe a bad t-stat? Not real sure on the timing yet, a lot of hand made parts (lower pulley spacer with timing marks). Thanks.
Re: overheating [Re: Xlr8us Rapidus] #1004221
05/31/11 11:54 PM
05/31/11 11:54 PM
More airflow for sure & possibly more water flow. I'd suggest tossing the elec fans/w pump & subbing in mech units
Re: overheating [Re: Xlr8us Rapidus] #1004222
06/01/11 12:18 AM
06/01/11 12:18 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
take off the cap, and look for water flow. if the upper hose is cool, i'd want to see water flow first. try running without the thermostat and see what happens. worse case scenario, remove the pump and run it, and verify the direction of the impeller is the direction it's actually spinning. if it's running backwards, reverse the wires.
Re: overheating [Re: Golden-Arm] #1004223
06/01/11 09:21 PM
06/01/11 09:21 PM
Western NY
super gas
super gas
Western NY
Thanks for the replies. Pulled the t-stat and tested it, doesn't open til almost 200 deg. Water pump seems to going the correct way. I think I may have a bad t-stat. I'm going to try to get a 160. Also may have air trapped under t-stat, might try drilling a burp hole in the stat. It's just such a pain to r & r the t-stat with the pullies an belt and no room to work.
Re: overheating [Re: Xlr8us Rapidus] #1004224
06/01/11 09:45 PM
06/01/11 09:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
A stat (unless it is bad) will not cause a heating problem. It cannot control temps above the stat rating. A 195 stat will not be open till near 200 degrees and that will not hurt a thing.
Re: overheating [Re: Xlr8us Rapidus] #1004225
06/01/11 09:48 PM
06/01/11 09:48 PM
Kirkland, Washington
Pacnorthcuda Offline
I wouldn't go to a 160-that really isn't hot enough, especially if the rest of your cooling system is in good shape. 180 would be a good choice---AND get a high flow stat.
And test it first!
Re: overheating [Re: Pacnorthcuda] #1004226
06/02/11 09:29 AM
06/02/11 09:29 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
180 Napa Superstat.
Re: overheating [Re: Xlr8us Rapidus] #1004227
06/02/11 10:35 AM
06/02/11 10:35 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Good luck cooling that thing with electric fans, lol
You need to work on the tuneup, not the cooling system.
Re: overheating [Re: Challenger 1] #1004228
06/02/11 05:23 PM
06/02/11 05:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If the top hose is cool and the bottom hose is hot you've already found the problem.
It's not moving water.
Take the top hose off the radiator and turn on the pump. Does water come out?
If not, pull the thermostat and see if the pump pushes water out the top of the pump.
The only other culprit would be the bottom hose sucking shut but if the bottom of the radiator is hot water is moving through it.
- Stu Harmon
Re: overheating [Re: feets] #1004229
06/02/11 10:16 PM
06/02/11 10:16 PM
Western NY
super gas
super gas
Western NY
Thanks again for all the replies. This is my first blown motor, and my first Hemi. I think we got the overheating thing licked. We replaced the stat (tested it 1st), and set the timing to about 20 deg. It seems to run at around 190 degress now. I think we need to play around with pulleys now. Too much boost! 15 lbs at idle!!
Re: overheating [Re: Xlr8us Rapidus] #1004230
06/03/11 04:07 PM
06/03/11 04:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
15 psi boost at idle is a nice start.
- Stu Harmon
