Magnum 500 rims #1004199
05/31/11 11:28 PM
05/31/11 11:28 PM
NY
Beep Beep Offline OP
NY
I would like to upgrade from the factory 14 inch magnum rims on my 69 Roadrunner to 15 inch magnum rims. What size rim can be used in the rear and the front? Also what size tires for front and rear? Will a 275/60r15 fit on the rear? Pics would be great.
Re: Magnum 500 rims [Re: Beep Beep] #1004200
05/31/11 11:54 PM
05/31/11 11:54 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
My 70 coronet fits a 275/60/r15 tire with no problems on an 8" wide wheel, should be very similar to a RR. I would say either 15x6 or 15x7 for a wheel on the front with a 225/70/r15.
I could get you a pic tomorrow of what the coronet looks like.
Re: Magnum 500 rims [Re: BEINGmeISaCRIME] #1004201
06/01/11 12:07 AM
06/01/11 12:07 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, I have had Plymouth Road Runners and Dodge Super Bee's and the Dodges have a larger rear wheel well so you can get a larger tire on them the Plymouths ...a 15 x 8 works good with a 275/60 15...and I have used 15 x 7's on the front with 245/60 15 tires with no problem.
Re: Magnum 500 rims [Re: BEINGmeISaCRIME] #1004202
06/01/11 09:36 AM
06/01/11 09:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Coronets have much larger wheelwells than the Plymouth B bodies do as stated so your example doesn't really answer his question.
Re: Magnum 500 rims [Re: JohnRR] #1004203
06/01/11 10:34 AM
06/01/11 10:34 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Rears - 15x8's with 275-60-15's
Fronts - 15x7's with 235-60-15's
Re: Magnum 500 rims [Re: gtx6970] #1004204
06/01/11 10:35 AM
06/01/11 10:35 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ft
Re: Magnum 500 rims [Re: gtx6970] #1004205
06/01/11 05:18 PM
06/01/11 05:18 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
15x8s, 4.5 BS, front & rear on my '68 Roadrunner. No rubbing. 265/50s front, 295/50s rear.
Re: Magnum 500 rims [Re: JohnRR] #1004206
06/02/11 03:50 AM
06/02/11 03:50 AM
Kansas
Kansas
True, it would've helped if I included more information in my original post. Such as the links provided, that might give you an idea.
http://moparforums.com/forums/f10/69-road-runner-tire-rim-sizes-1413/
or
https://board.moparts.org/ubbthreads/show...rue#Post5237205
Re: Magnum 500 rims [Re: BEINGmeISaCRIME] #1004207
06/02/11 10:16 PM
06/02/11 10:16 PM
NY
NY
Thanks to everyone that responded to this question. Looks like I will go with the 15x8 for the rear with a 275/60/r15 and a 15x7 for the front with a 235/60/r15.
Re: Magnum 500 rims [Re: Beep Beep] #1004208
06/03/11 12:04 AM
06/03/11 12:04 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Just tried to get 235/60/15 radial TA's. Seem to be back ordered for last few months!
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: Magnum 500 rims [Re: 440PURSUIT] #1004209
06/04/11 08:26 AM
06/04/11 08:26 AM
NY
NY
Do the P235/60/r15 rub when cranking the wheel all the way and if you load the trunk will the rear 275/60/r15 rub.
Re: Magnum 500 rims [Re: Beep Beep] #1004210
06/04/11 10:03 AM
06/04/11 10:03 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
No,they do not rub,thats what everyone is running.Its best to buy everything through summit.The front will be hard to find right now if your going with ta radials as stated.The summit shipping used to be just a 1 time oversize charge when I got mine but were cheapest by far.
Re: Magnum 500 rims [Re: 70RR383] #1004211
06/05/11 07:37 AM
06/05/11 07:37 AM
NY
NY
Thank you I will look into it.
Re: Magnum 500 rims [Re: Beep Beep] #1004212
06/05/11 08:37 AM
06/05/11 08:37 AM
New York
tt455 Offline
tt455  Offline
New York
I went with 275/60 on 15x8's in the rear and 225/70 on 15x7's up front which fills the well nicely on my 70 RR.
Re: Magnum 500 rims [Re: tt455] #1004213
06/05/11 08:55 AM
06/05/11 08:55 AM
NY
NY
Very nice!
