Vintage Ladder Bars - What do they fit?? #1004110
05/31/11 10:12 PM
05/31/11 10:12 PM
CentralVA.
BBCoronet Offline OP
CentralVA.
I've had these for probably 20 years and have no idea what they are for.......IIRC They were in the trunk of 73 Chevelle we towed. Anybody have an clue?.....Could they be used on a Mopar?
Re: Vintage Ladder Bars - What do they fit?? [Re: BBCoronet] #1004111
05/31/11 10:13 PM
05/31/11 10:13 PM
CentralVA.
CentralVA.
Pic #2
Re: Vintage Ladder Bars - What do they fit?? [Re: BBCoronet] #1004112
05/31/11 10:59 PM
05/31/11 10:59 PM
moparx Offline
moparx  Offline
those are the basic gm "lakewood"[style] bars for a gm coil spring rear. they clamp to the housing and the brackets at the front tie into the front mounting bolt of the lower control arm front mount. you could probably make them work but
Re: Vintage Ladder Bars - What do they fit?? [Re: BBCoronet] #1004113
05/31/11 11:20 PM
05/31/11 11:20 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
When I read your post topic I immediately thought "On a Chevy". Then I read your post... Good for a laugh. Clean 'em up. Sell 'em to a Chevy guy.
Re: Vintage Ladder Bars - What do they fit?? [Re: moparx] #1004114
06/01/11 12:06 PM
06/01/11 12:06 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Actually those are the weld on Lakewood ladder bars. The clamp on ones mentioned above had totally different front and rear brackets to bolt onto Chevelle, GTO, 442 etc chassis. Lakewood stills sells the bolt on models but the weld on bars like the original poster has are long gone. I would not use these as there is no adjustment and far better choices are available. Once these are welded on, they are what they are. You may/will have to use an airbag to make it go straight.
Thats what I would do. And that Chevy guy will probably be at least 60 years old because those bars where designed 40+ years ago and somewhat popular in the 70's (just not on Mopars).
Re: Vintage Ladder Bars - What do they fit?? [Re: GomangoCuda] #1004115
06/01/11 06:13 PM
06/01/11 06:13 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Actually those are the weld on Lakewood ladder bars. The clamp on ones mentioned above had totally different front and rear brackets to bolt onto Chevelle, GTO, 442 etc chassis...
That is correct. The bolt-on units were way more complex, attaching to the axle, swing arm and frame rail.
Lakewood ladder bars were a step up from "Traction Bars" at about 3 times the price. They gave you that funny car look to go along with your N50 rear tires, long shackles and Gabriel HyJackers. And they do work.
I believe there was a bolt on version of those bars for leaf spring suspended cars that had the 4 bolt brackets on the axle end and a flat floor plate for the front end.
I think those would look super cool on a day-2 restored B body. Just fab up some U bolt brackets and set em up so that they don't obstruct anything. Would love a pair on my bee.
I’m listening.
Re: Vintage Ladder Bars - What do they fit?? [Re: Big Bad Bee] #1004116
06/01/11 07:31 PM
06/01/11 07:31 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I didn't recognize that front bracket at all and my immediate thought before reading the post was it must be a weld on bracket---guess I was right.
I took a set of the bolt on style and made them fit my truck, but they will be coming off as I am a little more interested in making it handle rather than going straight. They are indeed as posted a step up from a typical traction bar, but I admit I went after more as a look than anything else. But with the yellow shocks and chrome rear cover, it was a perfect match for the vintage look.
Outcast Dodge guy.
Re: Vintage Ladder Bars - What do they fit?? [Re: Big Bad Bee] #1004117
06/01/11 10:30 PM
06/01/11 10:30 PM
moparx Offline
moparx  Offline
you guys are correct. the bolt on bars had what was probably a 3" muffler clamp u-bolt to attach over the rear tube & thru the "saddle" on the upper part of the bar[note how the saddle looks suspiciously like the saddle of a muffler clamp in size and material thickness]. there was a triangular pc. comming off the rear part of the bar[pointing inward] that bolted to the lower control arm. the forward mount was more complicated than the one shown, in that it was also triangular in shape and captured the frontpivot of the bar in double shear. my response was just to indicate that it was a "style" of gm coil spring bar, and i'm pretty sure there was a company or two other than lakewood that made similar setups. hopefully, i didn't cause too much confusion.
Re: Vintage Ladder Bars - What do they fit?? [Re: moparx] #1004118
06/01/11 10:50 PM
06/01/11 10:50 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
You guys can laugh all you want but with my current setup untested, the fastest my R/T has ever 60ed was 1.32 with the "GM" setup at Bristol, I hope the caltracks/monos can match that.
The bolt ons are held on by full width clamps with 4 large bolts per.
They work, sorry if some are mad GM came up with them before ma mopar did.
Re: Vintage Ladder Bars - What do they fit?? [Re: quick77rt ] #1004119
06/01/11 10:58 PM
06/01/11 10:58 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
OK, that was a bit harsh...but this is how the bolt on ones I had were, no cheap clamp and I tacked them in a couple spots while they were on.
Re: Vintage Ladder Bars - What do they fit?? [Re: BBCoronet] #1004120
06/02/11 12:02 AM
06/02/11 12:02 AM
CA
David Lee Offline
David Lee  Offline
CA
we mopar people do not need to ude ladder bars, the SS springs are much better
Ah...so many pedestrians, so little time...
Re: Vintage Ladder Bars - What do they fit?? [Re: David Lee] #1004121
06/02/11 03:24 AM
06/02/11 03:24 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Those are the deal. I had them on a 65 Olds 442. Stopped the nasty wheel hop created by those cheesy GM springs.
Now the real question is how to mount them correctly on a leaf spring rear end. If they aren't the same length as the spring from axle center to front perch, the ladder bars and leaf spring will try to make the rear axle swing on conflicting arcs. So from what I've heard (not experienced), you either have to allow the axle to SLIP in it's spring perches or allow the nose of the ladder bars SLIDE forward and rearward in their front perches to compensate for the difference. 85 ram 4 speed, how did you set yours up?
BTW. I agree, SS springs as they are engineered are pretty darn awesome and I'm not advocating ladder bars as an alternative or supplement. I just love the look.
I’m listening.
