Exhaust "clamps" on hot side? #1004036
05/31/11 09:14 PM
05/31/11 09:14 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Looking to keep my hotside plumbing simple and make it easier to remove and I was wondering if there was a reason these wouldn't work...
http://www.jegs.com/i/Dynomax/289/33240/10002/-1?parentProductId=744706
I haven't used them before so I'm looking for some opinions. I was thinking they might provide a relief point for expansion too
Re: Exhaust "clamps" on hot side? [Re: SLOW67] #1004037
05/31/11 09:54 PM
05/31/11 09:54 PM
Borden, Indiana, U.S.A.
W
wrenchinrandy Offline
W
I have no experience with this style of clamp upstream of the turbo's. I did however use them at a slip joint in my down pipes. To date they have been flawless. I purchased mine through a local heavy truck parts supply. It is my understanding that heavy trucks use these frequently, but again, I don't know if they are acceptable in the higher pressure area upstream of the turbo's.
Re: Exhaust "clamps" on hot side? [Re: wrenchinrandy] #1004038
05/31/11 09:59 PM
05/31/11 09:59 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Thats what I was afraid of it blowing apart. It will be "blocked" so to speak from the back by the header so it might take it idk
Re: Exhaust "clamps" on hot side? [Re: SLOW67] #1004039
05/31/11 10:14 PM
05/31/11 10:14 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
You would be surprised at how much pressure 8-10 lbs really is! You gotta use good v-band clamps for the pressure/hot side!
Use these,
http://cgi.ebay.com/ebaymotors/OBX-2-5-V...sQ5fAccessories
They have a inner flange for positive seal.
They are a bit pricey but well worth it. I paid more for the 3". $38 shipped and I used 5.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004040
06/01/11 12:56 AM
06/01/11 12:56 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Those clamps are useless against turbo backpressure I tried it. Use ball flange or v band. I had the best luck with ball flange as they are more forgiving.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Exhaust "clamps" on hot side? [Re: SLOW67] #1004041
06/01/11 10:11 AM
06/01/11 10:11 AM
NY usa
540challenger Offline
NY usa
I love the clamps you posted the link for exhaust, however using them on a boosted application would be a boost leak nightmare.
Even when used on exhaust the part where the band is pulled together almust always has a slight leak that you can see when you remove the clamps.
Nothing you can hear or worry about on a exhaust but on a boosted motor
Re: Exhaust "clamps" on hot side? [Re: 540challenger] #1004042
06/01/11 01:26 PM
06/01/11 01:26 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I'll go with the v bands then I only need one for the cross over to be removable the rest already have flanges at the headers and it will be welded solid at the turbo support bracket. I just want the ease of removal because I'm mocking it all up on my 273 then taking it all back apart to clean and paint it to put it back on the 318. I'm sure the 318 isn't going to last long under boost anyway lol so I don't want to have to fight it when I go feeding it shortblocks
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004043
06/01/11 02:01 PM
06/01/11 02:01 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Use these,
I've used these ebaggers with much success!!
Re: Exhaust "clamps" on hot side? [Re: Shaker223] #1004044
06/01/11 09:53 PM
06/01/11 09:53 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Do you have to butt weld the v bands or does the pipe slide inside the flange it comes with?
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004045
06/01/11 10:24 PM
06/01/11 10:24 PM
Oakley CA
69charger440_6pa Offline
Oakley CA
Use these,
damn i wish I knew those exsisted on ebay. I just spent more than $50 each for 6 of them on my exhaust from summit.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Exhaust "clamps" on hot side? [Re: SLOW67] #1004046
06/02/11 01:34 AM
06/02/11 01:34 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
The pipe will go into the flange about a sixteenth of an inch. Be sure to hit the edge of the flange with a 36-grit disc so the weld doesn't splatter due to contamination. I made the mistake of buying "Aluminized" mild steel pipe. Hard as heck to get that coating off for welding!!
Re: Exhaust "clamps" on hot side? [Re: 69charger440_6pa] #1004047
06/02/11 01:41 AM
06/02/11 01:41 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Use these,
Almost my entire build was obtained from there. Found the best deal on a Hallman manual boost controller too.
Looks like his intercooler is the exact same one I got for $145.00. Had to flip one tank so the inlet would be at the bottom and the outlet to the top. Came with a load of clamps, 3 ply couplers and 3" polished aluminum pipe.
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004048
06/02/11 12:03 PM
06/02/11 12:03 PM
IL
furious70 Offline
furious70  Offline
IL
There are what I used:
http://www.mandrel-bends.com/catalog/fla...sembly-778.html
The pipe slides all the way through them, which was sometimes a problem. Got all my pipe from them too, and the straight vs bends seemed to have a decent variance in the OD, so some of them fit tight, some had slop that made it harder to get a good joint.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004049
06/02/11 12:43 PM
06/02/11 12:43 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Use these,
Not these!!!
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004050
06/02/11 06:12 PM
06/02/11 06:12 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Re: Exhaust "clamps" on hot side? [Re: CUUDAK] #1004051
06/03/11 12:00 AM
06/03/11 12:00 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Use these,
Same intercooler lol The only gripe I had about it is it only came with one 90 and one 45 couplers...I need two of each
