Re: ATF4 in A833, good? bad? ugly?
[Re: mshred]
#1004004
06/23/11 10:32 PM
06/23/11 10:32 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
not to resurrect an older thread, but i feel i need some advice.
some of you have seen and replied in my other thread about my A833 grinding when i make the 1-2 shift under partial or hard throttle, but not under very light acceleration. I have taken the whole transmission apart and inspected every peice, and everything is working and worn as it should be with no visible issues at all. I changed the fluid in the transmission to AC delco synchromesh, and now im wondering my problem is the fluid im using?
Im thinking of trying ATF since i see quite a few people recommend it, and since its also dirt cheap and there is no non GL5 gear oil on any shelf here. Im wondering though what kind of ATF should I be trying? Dextron? Mercon? straight ATF? does it matter if its Dextron 3 or 4? Just looking for some input here since id like to refill the trans with ATF and see what happens
Forget that idea. Its not the fluid. Think about it, if it was an issue of the fluid(which it clearly isn't), then why only 2nd gear? Follow that logic?
Did you do what I mentioned for you to do in tn my previous post in this thread?
MB
[Re: HPMike]
#1004005
06/23/11 10:41 PM
06/23/11 10:41 PM
Posts: 3,414 Toronto
mshred
Toronto
MB
I posted in that thread last night. I did everything you told me and checked every last part, its all working fine and it good order...this is why im thinking possibly the fluid? I know it sounds weird that its only affecting one gear, but ive been searching the hell outta what fluid to use and it seems that some guys who had problems with only one gear changed fluids, and voila! problem fixed.
I havent actually driven the transmission yet since fixing it, so i was thinking of trying a different fluid to see where it would get me. I still have the drained synchromesh
[Re: ahy]
#1004007
06/23/11 11:57 PM
06/23/11 11:57 PM
mshred
Toronto
Having tried many fluids the best for a getting a "touchy" transmission to shift well is Redline synthetic. Its available in two grades: "MTL" which is 70W80 from memory and 90 weight. Either one would work in an 833 - I'd suggest the MTL for easiest shifting with adequate protection of bearings/gears. Summit and others sell it.
I believe the ATF and syncromesh options are too light for an 833 (I know, controversial topic). That said if it won't shift smoothly on syncromesh you might well have problems with the hard parts as posted above.
Well the hard parts have been inspected as per instructions here by a qualified manual transmission mechanic and everything is in good working order. I was kinda disappointed to not find anything wrong because now im really stumped. Gonna put it back on the road and see what happens.
Now im really confused...do i spring for some gear oil, or go to ATF? lol
[Re: DJVCuda]
#1004008
06/24/11 12:03 AM
06/24/11 12:03 AM
Posts: 4,951 northwest USA
NANKET
northwest USA
My dad is the original owner of a '70 challenger 383 4 speed car - he now has 114,000 miles on it. it had a rebuild at 112,000 miles and all that went in it was bearings, shift forks, seals, & gaskets. He towed a camper trailer from NJ to as far as Missouri. He also drag races it when he has time and is never easy on it.
DJV CUDA, Please tell all of us the comlete story of why that 1970 Challenger has a 1971 and newer side cover on the trans. You posted a picture of the inside of that trans years ago and I remember you had more to tell about this trans than you are saying here. You had an explaiation for the side cover being changed. That will shed some more light on this original trans that wasn't rebuilt till 112,000 miles.
[Re: NANKET]
#1004012
06/24/11 09:01 AM
06/24/11 09:01 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Dad ordered this car in late 69, is was built in late '69 and he got it early 1970. during the first year of his ownership ( going by his story ) he has shifting issues with the original tranny, he had taken the car to Cherry Hill Dodge to have it looked at. He watched as they pulled the trans, pulled it apart, and proceeded to get looked over by about everyone in the shop, they came to him several hours later trying to say they had an issue with the tranny ( Syncros ) and it might be awhile before they could get him a new one, Dad apparently asked if they knew how to put the tranny back together with new syncros, and they told him no!
He had to wait and was given a new tranny. all was well for the next 112,000 miles.
When we rebuilt this ( with the help of Jamie Passon ) we ordered all the parts necessary for a 23 spline 833 and gave Jamie measurements on the front bearing that was supplied with the unit. We recieved the parts and then noticed that the bearing retainer was larger then the bearing. Calling Jamie Passon revealed that we had a small block tranny in a big block bell ( large retainer hole, small retainer bearing)
Jamie was excellent about swapping parts for us, and I bet he remembers this story to this day ( this was rebuild several years ago now)
Anyway, the car was run, with the 1971 tranny since late 1970 till about 2005 / 2006 with the bearing retainer not doing it's job, towing, racing etc... all not centered properly - the good thing is that it was centered close enough and didnt break!
Thats the whole story, probably still confirmable by Jamie himself.
We got it back together, needing new bearings, seals, gaskets, and shift forks.
Cherry Hill Dodge is still in buisness, and has about the same workmanship issues to this day...lol... he wanted to take it back to them and break balls since they didnt know what they were doing inthe first place and messed him us second!
[Re: DJVCuda]
#1004013
06/24/11 09:16 AM
06/24/11 09:16 AM
Posts: 5,337 the house on the left.
cogen80
a bunch of hacks at that place.
[Re: cogen80]
#1004014
06/24/11 11:13 AM
06/24/11 11:13 AM
DJVCuda
Atco NJ
[Re: HPMike]
#1004015
06/24/11 03:15 PM
06/24/11 03:15 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why only second gear? Because the ratio change from 1st to 2nd is larger than the other gears, so the stop rings have to work harder on the 1-2 shift.
Fluid type has an effect on stop ring efficiency, slippery fluid isn't good.
[Re: John_Kunkel]
#1004017
06/24/11 03:37 PM
06/24/11 03:37 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I have been using GM Synchromesh since it came out on COUNTLESS 833's and NEVER had a shifting concern like was described. IF it was the fluid it would have affected other speed gears as well, even if it was more pronounced in 2nd.
Then again, what do I know?
MB
[Re: John_Kunkel]
#1004018
06/24/11 05:16 PM
06/24/11 05:16 PM
mshred
Toronto
I have actually had guys tell me that ATF displaces better than synchromesh or gear oil which would be better for the synchros. I just picked up some Type F ATF for a pretty good price, so im going to try it out...hopefully it works but if not im going to have to special order some GL4...the transmission is gonna have seen every fluid besides engine oil lol
[Re: 68LAR]
#1004020
06/24/11 06:57 PM
06/24/11 06:57 PM
mshred
Toronto
I've NEVER tried Type F. I use Dextron.
I went with type F because it is supposedly the thickest of the ATF's...I"ll find out soon enough, just finished filling it up and waiting for good weather to go for a drive
[Re: mshred]
#1004021
06/24/11 08:35 PM
06/24/11 08:35 PM
Posts: 4,008 South Park, Pa.
68LAR
South Park, Pa.
Type F is supposed to have more friction modifiers in it. It's less sliperier.....
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
