'97 Dakota brakes
#100390
08/05/08 10:21 PM
08/05/08 10:21 PM
Posts: 1,453 WV
bacaruda
WV
At low speeds, too little front brake. Driving normal, pedal a little low, but stops fine. You can feel the rear bias at low speeds. I replaced master, no help. Pumping does not help. No warning light. 4wheel ABS. Anything to check before throwing expensive parts at it? Could this be the ABS controller? Either the computer or the hydraulic unit? Prop. valve? Thanks, Jim.
Re: '97 Dakota brakes
[Re: bacaruda]
#100391
08/06/08 12:17 AM
08/06/08 12:17 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you could possibly have a solenoid stuck closed or near closed, blocking fluid to the front. but that would still leave a hard pedal....maybe an internally leaking master cylinder?
**Photobucket sucks**
[Re: 70Cuda383]
#100392
08/06/08 10:08 AM
08/06/08 10:08 AM
Posts: 1,453 WV
bacaruda
WV
Master was first thing I did. Any way to check solenoids? Isn't there a line to each front? Which would be two solenoids? Don't know have never been here. Replace entire hydraulic controller? Thanks, any more ideas? Ron?
[Re: bacaruda]
#100393
08/06/08 10:29 PM
08/06/08 10:29 PM
Posts: 1,453 WV
bacaruda
WV
[Re: Fastback67]
#100396
08/07/08 10:26 PM
08/07/08 10:26 PM
Posts: 1,453 WV
bacaruda
WV
I'll check tomorrow. I think hold-off is to let drums take up clearance before disk apply, or may be backwards. Yes about pin purpose, jim.thorn@hds.comJ.
[Re: Fastback67]
#100399
08/08/08 08:05 PM
08/08/08 08:05 PM
Posts: 1,453 WV
bacaruda
WV
I'm pretty sure there is not a physical problem, I've had the truck since new, it has 230K mi. on it, and have done all maintenace. I had similar problem with rear seal a few years ago, replaced. Thought had same problem on other side, and everything dry. When had seal problem, ebrake was sticky, not now. I think I have fluid flow problem, but what do I know, it's still AFU. I have HCU coming (used), hopefully it'll have residual fluid in all the valves so I don't need DRB cycle bleeding on it. Thanks. Jim.
OBTW, rear not dragging. Awhile back I backed off rear adjustment, better for a day or two. Reverse braking about 10' a day, parking. We've been in house for 13 yrs., familiar with driveway characteristics. Not being smart, just answering questions you had. Anybody else?
[Re: bacaruda]
#100401
08/09/08 09:45 AM
08/09/08 09:45 AM
Posts: 233 NH
Fastback67
NH
"Better" for a day or two, or "Fixed" for a day or two? Are the rear brakes extra sensitive at really low speeds, idle to 5 mpg lets say? Just fishing for extra clues.
No appologies necessary. No offense taken. I only mentioned it because mine does the same thing occasionally on damp days.
[Re: Fastback67]
#100402
08/09/08 02:08 PM
08/09/08 02:08 PM
Posts: 1,453 WV
bacaruda
WV
I would say that it feels more like normal bias after adjustment. Yes the rear is extra sensitive at low speeds. No seals or hoses replaced, front hoses look good on outside, haven't looked at rear. Is it possible hose restriction would block fluid pressure to front? Then both hoses would be bad the same amount, braking balance L/R is good, NO pull whatsoever. As far as not letting pressure bleed from rear, I can pull either drum without backing off adjustment. Driven on same steep drive for 13yrs. If I have one of the boats on the back, it'll push rear around. If we don't come up with something, or the HCU doesn't fix it, I'll TEE the front lines and do away with AWALB. But it'd be nice to fix it, my wife won't drive it.
[Re: Fastback67]
#100405
08/10/08 07:59 PM
08/10/08 07:59 PM
Posts: 1,453 WV
bacaruda
WV
I do a 200 mi round trip 2 or 3 times a mo., never sensed any obvious symptoms for drag. This is a mountainous drive. Still getting high 14 low 15 avg through the mountains. About as usual. Never noticed any smell, or heat "popping, creaking", but also never checked wheel temp either. Prob'ly not do anything with HCU until next weekend, maybe sooner. If that doesn't fix, or if I don't find a drag problem, we'll do a major brake overhaul. Thanks Mike, J.
[Re: bacaruda]
#100406
08/13/08 10:12 PM
08/13/08 10:12 PM
Posts: 1,453 WV
bacaruda
WV
Update, did the mountain drive yesterday, ran 62mi., got off interstate and stopped without touching brakes. Drums cool to touch. Then I got an IR temp. gun. 14mi. rural drive to work, LR drum 105*,RR 225*, front rotors within 10* OF EACH OTHER. Other driving scenarios show RR drum allways hotter 30 - 100*, than LR. So might be something here for the close clearance/retracting. Plan, hoses seem out of equation, or rear would be same temp. Cylinder(S), springs, yes on the plan. Jim.
[Re: Fastback67]
#100408
08/17/08 10:17 PM
08/17/08 10:17 PM
Posts: 1,453 WV
bacaruda
WV
Mike got it, sorry to not respond, as have been taking care of domestic recreation issues. I'm going to be armed with parts next weekend. That's if I don't get sidelined with above problem again....
