Oil pan for 440 A-body swap #1003867
05/31/11 05:09 PM
05/31/11 05:09 PM
California
70Drop Offline OP
70Drop  Offline OP
California
I am swapping a 440-based 500-inch stroker into my '70 Duster and planning to use Schumacher swap mounts (the car has a small-block K-member). I have the 187 oil pan that Schumacher recommends (it has a recessed area for steering linkage clearance). However, my engine will be making about 600 horsepower, and the car will be seeing some time at the drag strip. There's no way I would use that 4-quart non-baffled 187 pan as-is - I would want a deep sump and baffles. I've been told that I can weld the sump from another pan onto the bottom of the 187 and fabricate some kind of a baffle. However, that seems like a lot of work. I've seen a post on another site where someone said he had successfully used the Moroso pan No. 20760 with very little modification necessary. Even if I had to spend some time heating and pounding on the Moroso pan, I figure it would be a better solution than using that 187 pan. Does anyone have experience with this?
Re: Oil pan for 440 A-body swap [Re: 70Drop] #1003868
05/31/11 05:29 PM
05/31/11 05:29 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've used both a Moroso and Milodon pan with no problems.I prefer the Moroso.440 in a 1971 Demon.
Nautilus Racing-
Re: Oil pan for 440 A-body swap [Re: 70Drop] #1003869
05/31/11 05:44 PM
05/31/11 05:44 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
You can use the deep sump pans just be careful how you street drive it as the pan is out there unprotected.
Yes you will see a number of members say they have been street driving with these types pans on wagon rutted roads since the dawn of time , but I know a few people that have ripped them open driving on the street ...
Re: Oil pan for 440 A-body swap [Re: 70Drop] #1003870
05/31/11 06:12 PM
05/31/11 06:12 PM
Not what you requested but I'd properly baffle the 187 & maybe run an extra qt on strip days. I'm more concerned w internal oiling mods as opposed to the pan running dry and I think when it's been reported that it is due to not enough pickup/pan clearance (I like 1/8") like a straw too close to the bottom of a milkshake rather than the pan being sucked dry from either a hi vol pump and or not enough sump capacity as commonly blamed
Re: Oil pan for 440 A-body swap [Re: 70Drop] #1003871
05/31/11 07:22 PM
05/31/11 07:22 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I used the 187 pan on my 440 Valiant. I added a baffle. I posted the pattern for the baffle on Bigblockdart.com i used the Schumacher mounts too. The steering arm rubbed slightly, had to dent the high point. when I race I add an extra quart. I will try and take a picture and post it.
Re: Oil pan for 440 A-body swap [Re: R/T1968R/T] #1003872
05/31/11 08:00 PM
05/31/11 08:00 PM
California
70Drop Offline OP
70Drop  Offline OP
California
Thanks! I found the template. I guess that might be an option, as well, if I added an extra quart on track days. What gauge steel should I use?
