next project - #1003697
05/31/11 02:17 PM
05/31/11 02:17 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
I picked this up off Kijiji last night...looks to be in great shape, just needs a good cleaning (I will probably paint it anyway)!
I paid under $200, which is the best deal I could find on any intake!
Looks like I will have a little work to do over the next few weeks.
Looking for better low end and part throttle driveability.
SO any suggestions on intake gaskets??
Just thougth I would share!
Re: next project - [Re: CUDAJAS] #1003698
05/31/11 02:18 PM
05/31/11 02:18 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
pic 2 for fun!
Re: next project - [Re: CUDAJAS] #1003699
05/31/11 05:21 PM
05/31/11 05:21 PM
I like the composition ones as opposed to the steel shim ones but do set the intake in place on your choice of side gaskets (no front/rear gaskets) & check bolt hole/port alignment which will affect your choice and I use a wide carefully placed swath of clear silicone (front/rear) instead of the supplied end gaskets on brake kleened surfaces as alot of them esp the cork ones are too thick & will effect a front port(s) head/intake water leak over time. RPM's are tall so b sure to check hood/air cleaner clearance b 4 you shut the hood
Re: next project - [Re: RapidRobert] #1003700
05/31/11 05:37 PM
05/31/11 05:37 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Thanks for the tips.
I am currently running a Torker 340..so I think I will be good on hood clearance.
Jason
Re: next project - [Re: CUDAJAS] #1003701
05/31/11 06:26 PM
05/31/11 06:26 PM
scratchnfotraction Offline
fel-pro 1213 gaskets has the heat cross over blocked
