Edelbrock SB 318/360 heads on a 340 #1003423
05/31/11 09:15 AM
05/31/11 09:15 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I'm working on a buddies 340 motor. He picked up some edelbrock SB heads cheap but not the 340 specific ones and sure enough he's got pistons that hit with an .039' gasket.
I'm guessing the only solution other than trading for the right heads (or pistons) would be to set the heads on a mill and cut an open chamber to clear. I'm guessing this is all Edelbrock does? They "make" a 340 head by just milling a std head?
If so, what would I want to shoot for for quench?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Edelbrock SB 318/360 heads on a 340 [Re: CJK440] #1003424
05/31/11 10:35 AM
05/31/11 10:35 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The guy who bought my little 341 lives in TN and he accidently bought a pair of the open chamber 340 Eddies, maybe y'all can arrange a swap??
WIZE
In Car:
Re: Edelbrock SB 318/360 heads on a 340 [Re: Streetwize] #1003425
05/31/11 12:48 PM
05/31/11 12:48 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
just stuff a thicker gasket in there
Re: Edelbrock SB 318/360 heads on a 340 [Re: Baxter61] #1003426
05/31/11 12:54 PM
05/31/11 12:54 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
On his next build if he uses the same heads it is easier to source pistons for the 318/360 closed chamber.
68 Barracuda Formula S 340
Re: Edelbrock SB 318/360 heads on a 340 [Re: CJK440] #1003427
05/31/11 01:27 PM
05/31/11 01:27 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Does he want to sell the heads? If so , PM me.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Edelbrock SB 318/360 heads on a 340 [Re: 11secaarcuda] #1003428
05/31/11 06:43 PM
05/31/11 06:43 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Head gasket will fix it, we run the 318 head on a 340 with the piston out of the deck.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Edelbrock SB 318/360 heads on a 340 [Re: 65signet] #1003429
05/31/11 06:53 PM
05/31/11 06:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Me too, thicker gasket, no biggie.
Re: Edelbrock SB 318/360 heads on a 340 [Re: 65signet] #1003430
05/31/11 07:23 PM
05/31/11 07:23 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
How thick is your gasket and if you measured, how much piston to head clearance do you have? Thanks........
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Edelbrock SB 318/360 heads on a 340 [Re: D-50] #1003431
05/31/11 08:58 PM
05/31/11 08:58 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I think a thicker gasket of course would be the easiest but any concerns with intake/head matchup?
I don't have the motor here but he and his neighbor is saying the supposed .039 gaskets measure .030 and the piston is .028 out of the hole.
We decided to pull the whole motor and go thru the bottom end just for piece of mind. It was in the car when it was bought but no info on it at all. If the bores are all ragged out and it needs an overbore along with new pistons, than its simple...
Re: Edelbrock SB 318/360 heads on a 340 [Re: RobX4406] #1003432
06/02/11 12:24 PM
06/02/11 12:24 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
To get anything thicker than an .039" I'll have to step up to an MLS or ICS Copper gasket right?
I'd really like to keep it simple with a composition gasket.
Once I get ahold of it I'll know for sure but I suppose I can flycut the piston tops a bit and then have it rebalanced. Who knows if it ever was done before so I'd think it might be money well spent.
Re: Edelbrock SB 318/360 heads on a 340 [Re: CJK440] #1003433
06/02/11 05:49 PM
06/02/11 05:49 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the fel-pro's that come in a standard 318/360 rebuild kit are .054" thick compressed. if your pistons are the (IIRC) spec .018" out of the hole, that would leave .036" quench, which is tight, but OK
2017 Grand Cherokee Overland
