Page 2 of 3 1 2 3
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003185
05/31/11 11:08 PM
05/31/11 11:08 PM
I guess I din't make my post clear enough?
O.K.
One of my friends has a 1970 Dart with 31" tall tires, 15" wide and with 3:23 gears...727 automatic and a 360 Mopar performance crate engine -not sure on cam size but has an airgap intake and Holley 750 carb-(calabrated) and when we went to the Mopar Nationals last year on the higway gets aprox. 16-17 mpg
My wifes 72 Charger has a 3:23 rear 28" tall tires with a 727 transmission and a stock bore 400 engine with a 1963 2 4BBL intake and two 500 CFM Eldelbrock carbs ..runs good, no real power house but she likes it but doesn't get very good fuel econmy on the highway, best we have gotten is 12 mpg...
Very similar mpg on my old smallblock! I'm sure I could've tweaked it into the 20's pretty easily.
My 440 used to get 14 mpg tooling along at 70mph with 3.23 gears. Had a mild cam, headers and stock intake. 9.5:1 CR.
Re: Performance car...fuel economy....what do you get? #1003186
05/31/11 11:20 PM
05/31/11 11:20 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yea...I installed a 1996 318 Magnum engine out of a truck , installed an R/T cam, with a Mopar Performance 4BBL intake and Edelbrock 600 CFM carb with an A-518 and with 3:55 gears for a Customer. It runs real good and I am hoping the customer gets colse to the 20MPG with it also.
I have heard of 440's with six packs on them getting 16- to almost 20 mpg.....I had a 69 GTX years ago and I installed a 6-pack and I am quite sure I got 18 with it..
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003187
05/31/11 11:40 PM
05/31/11 11:40 PM
KS
68SportSatvert Offline
KS
This may be a bit off target but here's my take on our cars and the expense to drive them and have fun. Any of you own or ever own a boat? The pleasure of operating a boat is measured in gallons per hour. My point is this is a hobby and we need to enjoy our hobby the best we can. Maybe that means pulling the big block and dropping in a late model small block with FI and an o/d trans. Still get to enjoy the car and get good mpg but it may not have the grunt it had with the big block. That's the trade-off we make but still get to enjoy!
Re: Performance car...fuel economy....what do you get? [Re: 68SportSatvert] #1003188
06/01/11 08:33 AM
06/01/11 08:33 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yes...there is a trade off usually unless you happen to find a combination that works for you and your car. With all the new technology that is available now, it makes it a little easier to get the most out of the older engines or retro fit our older cars with the newer engines and transmissions to get more bang for our buck!..
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003189
06/01/11 08:41 AM
06/01/11 08:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
with my toy...it's a toy. if I can afford gas, then I go play. if I can't buy any gas, then I don't drive it.
lucky for me, it's VERY mild right now and gets good mileage.
what I'm currently driving around as my toy is a 98 regular cab dakota, 5.2L 5 spd, 2wd, 3.92 gears with an LSD. heads are shaved to up compression, it's got a 220 duration cam with a 114 LSA, 3" exhaust, and a custom computer tune on the factory PCM for the EFI.
I estimate it's around 300 hp right now, not blistering fast, but in this truck, it's enough to have fun with and make it an enjoyable ride. I can go WOT in 2nd gear around a corner and get the back end to slide out on me.
and, I'm getting 17 MPG on the highway...in what has to be nearly 4000 lb truck. --my other 98, a club cab, with a V6 weighed 4000 even with me in the seat, and that jumped up to 4200 when I had a big block with aluminum heads, intake, water pump housing, in it, so I figure this Reg cab V8 with iron heads is probably within a few hundred pounds of 4,000
**Photobucket sucks**
Re: Performance car...fuel economy....what do you get? [Re: 70Cuda383] #1003190
06/01/11 08:59 AM
06/01/11 08:59 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Sweet Ride...and you can haul stuff too!..:)
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003191
06/01/11 10:48 AM
06/01/11 10:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I won't be hauling too much with it! It's got drop springs on it, so it sits 2" lower up front and 3" lower in the back. I bet if I put more than 500 lbs in the bed, it'll be sitting on the bump stops, when my old V6 dakota has had up to 1700 lbs in the bed and was still driveable 15 minutes across town
I've got a motor in the works though...I don't think it'll be getting 17 on the highway anymore! 360 with a .030 head shave, 1008 fel-pro head gaskets to bump up compression considerably, and a nasty NA cam that's 230-ish duration on a 106 LSA. my engine program writer says he should be able to write an engine tune for it, but we may have to keep it in open loop full time, because the amount of overlap will drive the O2 sensors crazy, and the PCM might try to lean it out too far at part throttle cruise.
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003192
06/01/11 12:04 PM
06/01/11 12:04 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
The first iteration of the Valiant ran a decent 14.27 @ 94mph.
Mild 360. 9:1 compression, stock 1.88 valves w/ 3 angle valve job, MP ignition, eddy performer (non-rpm) 318/360 manifold, holley vacuum secondary 600, headers and an MP .450/.455 cam. Idled w/ 16 inches of vacuum.
Transmission was an 833OD unit. Gears 2.94, open diff.
On long hwy trips for which this thing was great, it usually returned b/w 20-22mpg, with one trip netting as high as 24-25. This was a mpg or two better than the tired 318 it had when I purchased it. By the end, with the mech secondary carb it was lucky to get 12mpg....
Purchased a coronet w/ a 318 from a member here. Stock long block/heads w/ offy intake, MP ignition, eddy 600 with new metering rods/jets, small summit cam, headers. 904 auto backed by 2.76 gears. Ran 15.1 @ 91mph, and driving back from maine the worst tank was 17.5 going b/w 75-85mph, best was 20.5 going 65mph.
Stock long block magnum w/ holley 600 and MP ignition, stock manifolds and eddy performer rpm intake in the Little red truck 15.1 @ 90mph, mileage b/w 15-16mpg reasonably driven.
all mileage are hwy mpg's.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Performance car...fuel economy....what do you get? [Re: Prince_Valiant] #1003193
06/01/11 01:15 PM
06/01/11 01:15 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you Chris!
Your Valiant and Coronet do quite well, and getting 15-16 with a truck is real good because trucks are about as aerodynamic as a brick!..LOL
I have a 1985 1 Ton crew cab 2WD truck with a 500 cubic engine, RV cam, Performaer RPM intake with a 750 Edelbrock, headers w/4:10 gears but the tires are tall..and I get around 10-11 MPG HWY..
I also have a 1987 D150 short box 2WD truck, with a 1970 383 Magnum engine w/performer intake and 650. Edelbrock carb with an 833 O.D. transmission and 3:55 gears and on a trip the best I have gotten is 13 mpg....
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003194
06/02/11 02:34 AM
06/02/11 02:34 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
My 70 road runner with a 440 B-1/TS heads A 696 roller 8IN 5000 stall converter 4.88 gears.Gets if your lucky 5 mpg
Re: Performance car...fuel economy....what do you get? [Re: pro6pakRR] #1003195
06/02/11 03:44 AM
06/02/11 03:44 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
HOW ABOUT this for a goal ? .... the ability to run 11.99 ...and get 20 mpg. And NOT with a steep OD manual trans or a high$$$ lockup OD auto trans OR super-trick converter.
A lite AERO car... with a short gear and a efficent/effective fuel delivery system.
As soon as I get settled in FL ... that will be my "mission" in life ....
Re: Performance car...fuel economy....what do you get? [Re: 68SportSatvert] #1003196
06/02/11 06:42 AM
06/02/11 06:42 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
And thats exactly what i plan on doing. My original big block build has become more ov a temporary fix now. I would completely abandon it for the new stuff, but i have pretty much all the parts, and unlike the modern stuff, its a very simple bolt-in... not a 3 month project involving engineers and scientists. So i'll build my stock stroke lowdeck for now with a 4-speed, but the PLAN is for a much smaller, lighter engine making about the same power or just a bit more, with EFI, 5 or 6 gears, and at least 200 less pounds over that long nose. Cant wait!
But for now, in my current car, the 72 Charger, life is a mess. Low-comp 440, 6-pack-ish cam (size), Holley SD manifold, Holley 750 vac-sec, stock heads, electric ign., Hooker Comps and a 3" mandrel X-pipe exhaust, 727 w stock converter, 8 3/4" w 3.23 sure-grip... 8mpg. Thats combined, though mostly in town... i rarely go anywhere in it due to cost. I dont give a [Edited by Moparts - Family Friendly Site - Keep it clean] HOW fast it is... (and mines not, particularly...) 8mpg is just not fun. Some ov us dont have good jobs or lines ov credit.
Hell, even my 68 Caddy hearse that weighs near-6000lbs (about 2000lbs... one TON more than my Charger) with its 30+ cid larger engine, the aerodynamics ov a freight train and 20ft ov heavy steel drivetrain (TH400, 2 shafts, massive coupler, massive axle and brakes, 31" mud tires) gets better mileage than the damn Charger... 11 combined last i checked... and thats with a pretty gross exhaust and single point ignition... and lots ov other issues to cost me mpg.
There was also a 'these are toys' comment in here, and thats the case for many here, but some ov us can only have one car insured... so if its not the 'toy' then its some POS and there is little use even owning the toy. My aim is to drive the toy every day, and actually get around in it... and i mean get around. Last time i had a good-on-gas car insured i'd find myself all over creation in it... just like you could do 20 years ago... And THAT... is 10X the fun ov owning a 600HP car that gets 8mpg and never leaves town in my opinion.
Re: Performance car...fuel economy....what do you get? [Re: pro6pakRR] #1003197
06/02/11 08:31 AM
06/02/11 08:31 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yea...pro6pakrr....Your 70 Road Runner...may be a gas guzzler...but I bet it is one fast runner at the track!
Re: Performance car...fuel economy....what do you get? [Re: dOrk !] #1003198
06/02/11 08:33 AM
06/02/11 08:33 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Doc...That is someting that a lot of us want...I hope things go well for you!...
Gary
Re: Performance car...fuel economy....what do you get? [Re: Pale_Roader] #1003199
06/02/11 08:38 AM
06/02/11 08:38 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
So....Pale_Roader ...is you plan to eventually build a small block Magnum engine or...one of the new Hemi's?
I was going to retro fit a 5.7 Hemi into a customers car but the customer desided that it was going to be too expensive to do, so he had me build and install a 5.2 Magnum for his ride.
Maybe soon ...it will be cheeper to do a 5/7 Hemi into an older car...time will tell..
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003200
06/03/11 02:32 AM
06/03/11 02:32 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
We hope to go mid 10's this year.
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003201
06/03/11 04:33 AM
06/03/11 04:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had a post like this awhile back and got many of the same responses:
Miles per gallon?
Who cares.... want MPG? Buy a Prius!
I get 2 gallons per mile!
Blah, Blah.... The OP was trying to poll fellow members and was hoping to learn a few things. Wheres the fault with that? Anyone that can dress themselves surely knows that heavy carbureted cars will not be gas misers. It makes sense though to look and compare what others are doing to try to improve where you can. Being wasteful isnt smart if you have the capability to improve.
My combo: 1970 Charger 3850 lbs. 440 based 493. Edelbrock aluminum heads, Performer RPM intake, Demon 850 carb. MP '509 cam, 2" TTI headers. 2 1/2" pipes to the bumper. 727 and 3.23 gears. 27 1/2" tire height. I got almost 11 mpg on a 900 mile round trip with speeds up to 100 on the freeway,(briefly) around town cruising and some idling. I had a 4.10 gearset in the car before the trip. I love the holeshot performance of the stiff gears, so I plan a Gear Vendors install later this year. The overdrive will put the 4.10 to 3.19 at freeway speeds. BEST of both worlds.
I could probably squeeze 2 more mpg with my combo by switching to a well tuned ThermoQuad. Who knows... Maybe I'll consider that next year.
Re: Performance car...fuel economy....what do you get? [Re: GLR] #1003202
06/03/11 07:20 AM
06/03/11 07:20 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Being wasteful isn't smart if you have the capability to improve.
Exactly. Inefficiency is just another form ov wasted power. We all want more power...
No new Hemi, still not a huge fan ov the idea. Also not a fan ov the Magnum smallblocks... just new(er) top end on an ancient engine. I like them... but not for this car. Think smaller... and DOHC...
Re: Performance car...fuel economy....what do you get? [Re: pro6pakRR] #1003203
06/03/11 07:43 AM
06/03/11 07:43 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
pro6pakrr......Well I am sure you will make your goal !... Good luck to you!...
Re: Performance car...fuel economy....what do you get? [Re: Kern Dog] #1003204
06/03/11 07:55 AM
06/03/11 07:55 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Frankenduster ...........
Yea...this post started out not so good because people didn't read and understand what I wanted from them.
anyway..........
Yea...I have a 493 also in my 1 ton 2WD crewcab shop truck, I have a 750 CFM Edelbrock carb on it, I think I will try a Thermoquad also... I am getting about 9-11 MPG with it now...
If six pack set ups were not so expensive I would try one of those because I have had them in the past and got some real good fuel economy and the performance was also great when you wanted it!.
Page 2 of 3 1 2 3
