Odd Oil Pressure **FIXED** #1003154
05/30/11 05:27 PM
05/30/11 05:27 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Just drove the 68` today and the oil pressure is all over the place?
Usually 80.lbs. Today fluctuates from 40 to 80?
Sitting still no problem,as soon as the car accelerates/slows it goes all over.
" Gee must be low on oil", checked that of course right on full.
Last time I drove it a week ago no problems.
Has a mech. gauge,engine is low performance 383 with maybe 5,000miles on it.
Have`nt got into it yet,oil pump? relief hanging?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Odd Oil Pressure [Re: 6bblFLASH] #1003155
05/30/11 05:38 PM
05/30/11 05:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try a filter change with a new WIX filter. NO fram.
Re: Odd Oil Pressure [Re: stumpy] #1003156
05/30/11 09:46 PM
05/30/11 09:46 PM
scratchnfotraction Offline
change the oil and filter
it will go up and down with the rpm going up and down.
mine when cold is 60 psi steady with low and high rpm till it warms up good.
then it drops to 30 psi at idle in gear and will go up to 50-55 psi with the rpm going up to speed,drops when it comes back down.
it is kinda normal for it to do that. IMO
cut the old filter to see if it has any metal shavings or debrie
Re: Odd Oil Pressure [Re: scratchnfotraction] #1003157
05/30/11 10:49 PM
05/30/11 10:49 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Might not hurt to plumb in another gauge to verify yours is right.
Old, tired, and sometimes broke down. Me, not my car...
Re: Odd Oil Pressure [Re: Shoozy] #1003158
05/30/11 10:55 PM
05/30/11 10:55 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
uNless you have a quality gauge in-there ...x 2
Re: Odd Oil Pressure [Re: dOc …] #1003159
06/05/11 09:44 AM
06/05/11 09:44 AM
N.E. Ohio
N.E. Ohio
Oil line was so over tightened the ferrel had pinched off the line.
Wiggled it and it fell off. OK now.
