Stall Converter Question #100254
08/05/08 03:34 PM
08/05/08 03:34 PM
New Zealand
solidcam Offline OP
solidcam  Offline OP
New Zealand
I have replaced a smallblock engine with an another engine that is 20 cubes less in displacement but makes 30 Horsepower more.The stall was around 3800 before but now seems higher.Does this sound right?I am just asking as I am wondering if the convertor is going off.What signs should I look for to determine if the convertor is going off?The trans is a 727,deep pan, reverse manual valve body.
Re: Stall Converter Question [Re: solidcam] #100255
08/05/08 03:35 PM
08/05/08 03:35 PM
Kirkland, Washington
Pacnorthcuda Offline
If you're now making more TORQUE your stall will be higher. Sounds like a good motor.
Re: Stall Converter Question [Re: solidcam] #100256
08/07/08 08:12 PM
08/07/08 08:12 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
cruise along at 15 to 20mph in 3rd gear and floor it..look at tach..it will jump momentarilly to where your converter is working
