400 Compression with kb 240 pistons ? #1002438
05/29/11 09:04 PM
05/29/11 09:04 PM
Gateway to the West.
hemi_harvester Offline OP
Anyone have a general idea of Compression ratio of these pistons (KB 240 KTM) with perma toqure Gaskets and stock 452 / 906 heads ?
Is it more that stock ?
Looking for 9.5 to 10.0
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 400 Compression with kb 240 pistons ? [Re: hemi_harvester] #1002439
05/30/11 12:29 AM
05/30/11 12:29 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm just RIGHT NOW working on same build, and reading all what I have read and calculate, will need to install metallick gasket ( .020 ) and cut the 452 heads around .040 or 1 milimeter ( factory volume is around 90cc ) to be able to get close to 9.5 CR
KB240s even better than the stock ones ( around .090 more CH ), still are around .020 down in the hole, and the valve reliefs adds volume. On my engine maybe less down the hole due the block was sleeved in the past, so cut to decking.
just with closed heads or cutting HEAVILLY the open heads will raise CR around 10:1, but cutting hard will compromise some of the geometry, and require adjustable rockers and/or rocker shims
Re: 400 Compression with kb 240 pistons ? [Re: NachoRT74] #1002440
05/30/11 07:30 AM
05/30/11 07:30 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
Even with 240's the compression still isn't that great. With stock heads and a 0.039 gasket I think it comes out to be 8.7 or so.
