Page 3 of 3 1 2 3
Re: Holley Carb Gurus-Help Needed [Re: Cuda367] #1002355
05/30/11 07:59 AM
05/30/11 07:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Many truck holleys had the idle screws in the rear metering block.
And what would be the reason for that
Re: Holley Carb Gurus-Help Needed [Re: joedust451] #1002356
05/30/11 12:15 PM
05/30/11 12:15 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Greg, thats an 800 DP. Most likely the jetting is 70-71 F/85 R, 50cc pump out back.
The Holley 8156 used that linkage and it was a 750.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002357
05/30/11 03:41 PM
05/30/11 03:41 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The metering blocks should have the list # on the top. If you could take a pic of that # we can read what it says.
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002358
05/30/11 04:15 PM
05/30/11 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002359
05/30/11 06:41 PM
05/30/11 06:41 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
What are the chances of it being a 8156 but you could be right, I'm bettin its a 4780 myself, but i've been wrong before.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley Carb Gurus-Help Needed [Re: joedust451] #1002360
05/31/11 09:00 PM
05/31/11 09:00 PM
Mi.
G-Money1320 Offline OP
Mi.
First thanks for the helpful info Here are some #'s the PV block has 7047 then 47812 on top and the rear 1 has 1116t with a deep 3 underneath. The base has 12R-4770B and 4895. The butterflies are 172's. Can I use the 800 base on the 650 with all the rest of the 650 parts and have a decent carb?
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002361
05/31/11 09:20 PM
05/31/11 09:20 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
My best guess here is its a 8156 and it does have the proper rear metering block and wrong front block. Have you looked to see if it has the rear idle circuts drilled?
If all four butterflys are 172 or 2 are 173's the base plate is a 750. 800 and 850's used 180's.
I'm still thinking your 650 is much better than what you are showing us here. Why don't you do some mods to the 650? like cut the air horn, blend the top and then do some tuning with the pumps, cams and squirters.
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002362
05/31/11 09:25 PM
05/31/11 09:25 PM
Mi.
Mi.
Thats probably the way im going, the horn is already cut on the 650 so I guess a good cleaning and tweaking is in order. The carb in question was just in better overall shape and looked like a better starting point, but now appears to be more of a hassle
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002363
05/31/11 09:28 PM
05/31/11 09:28 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
save it though. When you learn a little more or can get somebody to help you its a nice carb.
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002364
05/31/11 09:33 PM
05/31/11 09:33 PM
Mi.
Mi.
Thanks, too bad all you carb experts are days away Maybe Raff will put his touch on it when I see him
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002365
05/31/11 09:56 PM
05/31/11 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That can happen
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002366
05/31/11 11:38 PM
05/31/11 11:38 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yes you can, 650-800 use the same base
That 47812 metering block is from a 4781-2 850dp. Both metering blocks on the 850dp used PVs, so if it has no idle mix screws, its a rear MB.
Page 3 of 3 1 2 3
