Page 2 of 3 1 2 3
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002335
05/30/11 12:10 AM
05/30/11 12:10 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
your asking a lot from a conversation on the internet. I have no clue what baseplate you have what center section or what blocks you have. At this point i don't even know your engine/trans rear/use of your car. Its looking to me like you need to walk away from this carb or get somebody who knows holleys to go thru it for you.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002336
05/30/11 12:12 AM
05/30/11 12:12 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
, but it never hurts too learn.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley Carb Gurus-Help Needed [Re: joedust451] #1002337
05/30/11 12:14 AM
05/30/11 12:14 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I agree but at least post pics and some dimensions!
Re: Holley Carb Gurus-Help Needed *DELETED* [Re: bigtimeauto] #1002338
05/30/11 12:21 AM
05/30/11 12:21 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Post deleted by RAYS_W-5_69DART
Re: Holley Carb Gurus-Help Needed [Re: RAY1969CARS] #1002339
05/30/11 12:30 AM
05/30/11 12:30 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
WHAT IF IT WAS A PROFROM MAIN BODY ??? WHAT WOULD THE JETS BE ?? BUT WAS A 4779-7 2679
I had my PF MB jetted 73/82 on my 451, but you can start out with the jets that come with it, then jet for "best" MPH.
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002340
05/30/11 12:34 AM
05/30/11 12:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So if I use the front block from the 650 with idle screws and PV and the rear block from the 750 with the idle screws would I have a better tuneable carb? In your opinion is the front block I have really a rear that someone drilled and tapped for the PV? Thanks for your help Guess I should have stayed in school longer
Greg, if you look at the rear see how many bleeds are
on each side of the vent tube... even if you put
the metering block on the rear with the mixture screws
they wont do anything if its not set up for it...
put a 650 front metering block on the front and you
would have a good start
Re: Holley Carb Gurus-Help Needed *DELETED* [Re: joedust451] #1002341
05/30/11 12:36 AM
05/30/11 12:36 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Re: Holley Carb Gurus-Help Needed *DELETED* [Re: RAY1969CARS] #1002342
05/30/11 12:42 AM
05/30/11 12:42 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Re: Holley Carb Gurus-Help Needed [Re: RAY1969CARS] #1002343
05/30/11 12:52 AM
05/30/11 12:52 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
CAN YOU FIX A BROKEN booster ???? AND DOZ IT HAVE TO B A 750 ONE OR CAN IT COME OUT OF A 650 ???
PLUS WHERE DO I GET ONE ??
You should start your own thread, they call this high-jacking .
Re: Holley Carb Gurus-Help Needed [Re: joedust451] #1002344
05/30/11 12:58 AM
05/30/11 12:58 AM
Mi.
G-Money1320 Offline OP
Mi.
I tried to post some pics but they are too big for this site.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002345
05/30/11 01:02 AM
05/30/11 01:02 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Mike, why should he need to know how many bleeds are on each side in the rear, its still 2 on each side whether its 2 or 4 corner idle, what he would need to do is look at the underside of the MB to see if the idle feeds are drilled through, but thats an area for someone who knows what to look for, i did advize him to buy a holley tuneing/perf. book so he can get a better understanding.
Re: Holley Carb Gurus-Help Needed [Re: joedust451] #1002346
05/30/11 01:05 AM
05/30/11 01:05 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
BIG TIME HIGH JACKING! Like Joe suggests..please start your own thread..it would be the right thing to do.
Re: Holley Carb Gurus-Help Needed [Re: Labratt] #1002347
05/30/11 01:15 AM
05/30/11 01:15 AM
Mi.
Mi.
pics
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002348
05/30/11 01:16 AM
05/30/11 01:16 AM
Mi.
Mi.
#2
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002349
05/30/11 01:18 AM
05/30/11 01:18 AM
Mi.
Mi.
#3
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002350
05/30/11 01:24 AM
05/30/11 01:24 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Greg, thats an 800 DP. Most likely the jetting is 70-71 F/85 R, 50cc pump out back.
Re: Holley Carb Gurus-Help Needed [Re: joedust451] #1002351
05/30/11 01:29 AM
05/30/11 01:29 AM
Mi.
Mi.
It did have the 50cc in the back and the rear block has brass screw ins in the passages. This will be way too much for my car then wouldnt it?
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002352
05/30/11 01:41 AM
05/30/11 01:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Greg if you read all of this you will get a pretty
good idea how they function
http://www.holley.com/data/TechService/Technical/Carburetor%20Tech%20Info.pdf
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002353
05/30/11 02:16 AM
05/30/11 02:16 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
sorry guys
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002354
05/30/11 03:03 AM
05/30/11 03:03 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Many truck holleys had the idle screws in the rear metering block.
Page 2 of 3 1 2 3
