Page 1 of 3 1 2 3
Holley Carb Gurus-Help Needed #1002315
05/29/11 08:16 PM
05/29/11 08:16 PM
Mi.
G-Money1320 Offline OP
Mi.
A friend of mine hooked me up with a 750 double pumper and I need a little advice as to where to start with it. First it has 32 shot in the front and 42 in the back, with 82 jets in the front and 71's in the back. Now I know this probably is way off for my application so what would be a good base to start with?? Im switching from a 750 vacuum secondary that has a 25 shot with I believe 72 jets. Im running a good 340/auto,3.73 gears in a 3100# 69 Dart. Also shouldnt the idle adjustments be in the front metering block? They are in the rear block?? Im not good with carbs so I would appreciate some advice. Thanks1
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002316
05/29/11 08:25 PM
05/29/11 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Go to the Holley web site and set it up back to standard...
you gonna need the numbers off the carb.... yes the
primaries are in the front... thats the idle plate...
you sure you dont have it turned around backward...
because the jetting is backwards also
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002317
05/29/11 08:32 PM
05/29/11 08:32 PM
Mi.
Mi.
I put new gaskets and diaphrams on it today and while I was assembling it I noticed the blocks didnt look right, thats why I asked just in case, but the front one has the power valve in it-im so confused, The way I took it apart and reassembled it was the way I got it. Hi Mike
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002318
05/29/11 08:36 PM
05/29/11 08:36 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yeah, sounds like your looking at it backwards, the mix screws should be up front, most 750dpers are jetted 70/80 PV up front.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002319
05/29/11 08:39 PM
05/29/11 08:39 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I would install 31 squirters front & rear, 42 will be too much. You can get away with the 32 out back, just install a 31 up front. you can get away with the 71/82 jets for now.
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002320
05/29/11 09:00 PM
05/29/11 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Take it back apart... throttle linkage is on the left
(drivers side)... idle metering block goes in front
and so should the PV if running one... if using the
PV you will be about 8 jet sizes smaller on the front
than the rear... no PV in the rear... I tried to
pull up the specs for the different 750DP but the
Holley site isnt working right now
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002321
05/29/11 09:43 PM
05/29/11 09:43 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
You didn't post your list number so here are all of the specs for 750's i have: (all powervalves are in the front)
4779 c 750 (F)75,(R)76 8.5 4150
4779-1 750 (F)70,(R)80 8.5 4150
4779-2 750 (F)70,(R)80 6.5 4150
4779-3 750 (F)70,(R)73 6.5 4150
4779-4 750 (F)70,(R)80 6.5 4150
4779-5 750 (F)70,(R)80 6.5 4150
4779-6 750 (F)71,(R)80 6.5 4150
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002322
05/29/11 10:09 PM
05/29/11 10:09 PM
Mi.
Mi.
Well theres no choke horn on it to get the numbers from it, on the base it had 47708 and I just went out and took it apart again to verify the blocks are on right and now im even more baffled. The front block is indeed on right as it has the PV but no idle screws or even tapped for them, and the back block had the screws but not drilled for the PV.
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002323
05/29/11 10:15 PM
05/29/11 10:15 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
hmmm sounds like it was thrown togehter with mismatched parts. Might be better to move on if you don't know about carbs.
Oh and rear blocks did come with powervalve holes but were plugged on some carbs.
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002324
05/29/11 10:18 PM
05/29/11 10:18 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I missed the suirter question. most early ones with the small pumps used 25's and 28's the -1 and -2's used 28 and 31
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002325
05/29/11 10:19 PM
05/29/11 10:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep, sounds like a mix and match pile of parts...
you dont need the PV in the front BUT you do want the
mixture screws in the front.... the PV will help when
cruising
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002326
05/29/11 10:23 PM
05/29/11 10:23 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
cruising
I use a power valve on all cars in the front even the blowthroughs. Tons better driveability.
10 jet sizes makes for a fat low and midrange!
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002327
05/29/11 10:30 PM
05/29/11 10:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah they do help driveability, I usually run 8 jets
different then tweek from there
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002328
05/29/11 11:46 PM
05/29/11 11:46 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
If you can find a metering block with the idle screws & a PV provision you'll be good, then stick the one with no idle screws in back, You need to find a metering block off a DPer or at least a 3310 750, the 600 1850 will be too small for the metering, If you feel you don't want to tread in this area, just get another carb (preferably new) & move on.
Re: Holley Carb Gurus-Help Needed [Re: MR_P_BODY] #1002329
05/29/11 11:49 PM
05/29/11 11:49 PM
Mi.
Mi.
If this is a mix-matched carb, then why does the front have a PV and not the idle screws? I can understand the rear having them since it could have been a 4 corner idle carb. I do have a 650DP I could take the block from.
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002330
05/29/11 11:51 PM
05/29/11 11:51 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
because its a rear meetering block
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002331
05/29/11 11:53 PM
05/29/11 11:53 PM
Mi.
Mi.
Do the rears have PV's also?
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002332
05/29/11 11:58 PM
05/29/11 11:58 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
on some models they were drilled but plugged.
Re: Holley Carb Gurus-Help Needed [Re: bigtimeauto] #1002333
05/30/11 12:05 AM
05/30/11 12:05 AM
Mi.
Mi.
So if I use the front block from the 650 with idle screws and PV and the rear block from the 750 with the idle screws would I have a better tuneable carb? In your opinion is the front block I have really a rear that someone drilled and tapped for the PV? Thanks for your help Guess I should have stayed in school longer
Re: Holley Carb Gurus-Help Needed [Re: G-Money1320] #1002334
05/30/11 12:09 AM
05/30/11 12:09 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You "probably" don't have 4 corner idleing, so having rear idle screws will do you no good, Yes, it is a rear MB.
Page 1 of 3 1 2 3
